Condenser
Phil (NJ,AZ,Sas
09-20-2006 15:18:46
I came across my notes on problems found on my last Ignition (1997) fault that might help those having condenser problems Condenser wire connector: The connector utilized for ease of automation assembly has a barb to pierce the insulation (wire is not stripped) and provide the electrical connection to the wire. If you see insulation color in the crimp that is closest to the open end you may have a bad connection. (Note: the Crimp furthest from the open end is intended to be crimped on the wire insulation).
You can use small side cutters to catch the corners/end of the crimp (closest to open end)and open it up. Use a pick to remove the insulation from the wire and then close up crimp and solder connection.
Note: This is also a problem in cheap light fixtures (flicker & blow bulbs) and can be fixed the same way.
Hope this Helps,
