I have a similar one (from TSC), and, while it is a wonderful worksaver, be aware that SOME implements MAY not be able to be picked up by the quick hitch, due to brackets or framework being in the way of the hook at the top, and, also, some implements vary in the measurement from the centerline of the bottom pins, to the third-link attachment point at the top, requiring the top hook on the quick hitch to be unbolted, and adjusted up or down, when changing implements. I changed (with a cutting torch and welder) the top-link attaching points on a couple of implements, so they interchange quickly, but my Dearborn plow cannot be picked up, because of the top-link attaching point design, and I have (so far) chosen not to modify it 'cause of it being a collector's item. So, while I think the quick hitches are slicker than sliced bread, be aware of the POSSIBLE issues I mentioned. Also, at least with the unit from TSC, it comes with ONE set of sleeves that attach to the lower pins with rollpins, and you need to buy additional sets of those for EACH implement you want to pick up with the quickhitch.
