Adjustable Leveler Rod For Stablizer Bar
OldeSarge
09-22-2006 14:10:31
I have a '40 9N, which I just purchased. I am tinkering around with it some, and I have noticed that the hand crank for (leveling) adjusting the stableizer bar on the right rear side is pretty well frozen. I seen a new one that might do the job at TSC, but I am interested in trying to keep the original parts on this tractor. I have looked on here and a couple of other places, but have been unable to locate another one. The old crank almost appears to have possible been welded in much earlier days, which totaly baffles me. Does any one on here happen to have any idea of where I might possibly buy another rod? Thanks in advance.
Bill/Oh
09-23-2006 09:52:25
 Re: Adjustable Leveler Rod For Stablizer Bar in reply to OldeSarge, 09-22-2006 14:10:31
Mine is frozen solid too. I tried everything, even an acetaline torch to heat it up. Plus I cracked the bottom eye trying to heat and beat the bolt out. I have seen them in stock at the local supply store. Pretty common I guess. Pricey though $125.00, I guess I'll have to bite the bullet on that one. Good luck
Sean (TX)
09-22-2006 16:19:40
How about soaking it with penatrating oil? You can also buy parts to rebuild them.
OldeSarge
09-22-2006 16:30:41
 Re: Adjustable Leveler Rod For Stablizer Bar in reply to Sean (TX), 09-22-2006 16:19:40
Thanks. It appears that who ever had it many years ago decided to weld it for what ever reason. Thanks for your suggestion. byw, where in Texas are you located? I am about 25 miles South of San Antonio. Ron
Sean (TX)
09-23-2006 05:06:59
 Re: Adjustable Leveler Rod For Stablizer Bar in reply to OldeSarge, 09-22-2006 16:30:41
Im about 25 miles north of san antonio(Canyon Lake)
8n'r
09-22-2006 15:49:36
Sarge---for starters, there always seems to be lots of original parts available on EBAY for the N"s. You can put an ad in the classified section on this site as well. Good luck-Tim (WI)
OldeSarge
09-22-2006 15:54:07
 Re: Adjustable Leveler Rod For Stablizer Bar in reply to 8n'r, 09-22-2006 15:49:36
Thanks Tim..I looked on E-Bay several times but no luck, but will keep on lookin. Thanks for reminding me about the classified section on here. I have to admit I didn't think about that. Have a great evening.
8N'r
09-22-2006 16:02:44
 Re: Adjustable Leveler Rod For Stablizer Bar in reply to OldeSarge, 09-22-2006 15:54:07
Another suggestion is to find out the publication where the farmers in your area sell their equipment on--I picked up some good implements that way--Tim (WI)
