Re-torque Head Bolts
RickD
09-26-2006 06:42:01
I rebuilt my 8N engine and used a thread sealer- Permatex High Temperature Thread Sealer on the head bolts. I had read on the forum that when you use a thread sealer, the head bolt torque should be reduced. Although I can't remember what torque I did use, I now have a very slight seepage of oil coming from the headgasket area. I know you are suppossed to re-torque the head bolts after running the engine for a period of time after a rebuild, but I was affraid that a re-torque would destroy the effectiveness of the thread sealer I used so I did not re-torque. Should I re-torque now? If so, what setting do I use? Do I need to worry about the thread sealer? Thanks in advance.
TheOldHokie
09-26-2006 07:05:29
 Re: Re-torque Head Bolts in reply to RickD, 09-26-2006 06:42:01
According to the Data Sheet for that product (Data Sheet Here) parts may be repositioned up to 24 hours after application and is fully cured after 72 hours. I deduce from that that repositioning after the 72 hour full cure will compromise the seal. The sheet explicitly states that it allows for repositioning of parts "shortly after assembly".
They also claim "high lubricating properties" of uncured compound which would suggest that initial torque values for the bolts should be roughly equivalent to that for oiled threads. Since it's an anaerobic cure process (hardens in the absence of air) I'd expect the torque required AFTER curing to be considerably higher.
Personally I'd avoid using an anaerobic type sealant for this reason. The general purpose Permatex thread sealants (Pipe Joint Compound with or without PTFE) are good to 300F-400F and don't harden.
If I were you I'd retorque to a MINIMUM of 70#, prossibly a bit more, and monitor the performance.
YMMV,
TOH
Dan
09-26-2006 07:01:52
What did you use for a thread sealant? Permatex high temp red RTV is non-hardening and will not be affected by re-torquing the bolt. Torque it to the minimum accepted torque (65 lbs.), then again after warm up, then yet again after 30 minutes or so of run time. Crank it up to 70 lbs. the last time if needed.
Good luck,
Dan
