Order Ford 8N Parts Online
8n front distributor
rross
09-28-2006 16:54:18
I am getting no spark to the plugs. I have a 1949 8n. I took distributor apart, but how do I check the points or coil?
TennesseeMan
09-28-2006 17:37:47
 Re: 8n front distributor in reply to rross, 09-28-2006 16:54:18
I had a nightmare of a time once with my points. I replaced them and I liked to have never got the tractor to run. Come to find out I had a bad set of points and brass grommet where it hold them together was defective. Only after I put a meter to my distributer and points I was able find that they were grounded out. I guess the points came from China.
Bruce (VA)
09-28-2006 17:28:44
By 'took the distributor apart' do you mean you took it off the tractor? You check the points by seeing if they are burned, pitted or corroded & set them w/ a feeler guage at .015 on the high lobe of the cam. Pull the pigtail on the bottom of the coil & put it back together. Make sure the condenser wire is not grounded to the distrbutor base. Firing order is 1-2-4-3, CCW. If it does not start, check for a bright blue spark at the plugs by pulling one & grounding it to the block. Get back on the board, tell us what you did, and you will get a lot of help getting it running.
