How was the engine performing before it quit... power, oil pressure, oil consumption? Did it smoke at idle? When working hard? With an "N", almost certainly "oil" in the radiator is NOT actually leaked crankcase oil, since there's no way for that to happen, except POSSIBLY an (uncommon) oil gallery-to-water jacket crack, but rather, combustion products that have leaked over a long time past the head gasket, and accumulated in the cooling system.
So, it is quite possible the "oil" in the radiator is totally unrelated to the engine stalling, and the noise you heard. You really need to get a good diagnosis of why it quit, before being certain an overhaul is needed. A film of "oil" in the radiator is certainly NOT desirable, however, having coolant in the crankcase is 1000% WORSE, and will eventually cause the bearings to fail. A SERIOUS head gasket leak will allow water (coolant) to get into the crankcase oil, as well as "combustion products" to get into the radiator. Have you loosened the engine oil drain plug a little, to see what comes out... any coolant that has leaked into the crankcase will settle to the bottom, and drain out FIRST, before the oil.
