Water coming out of intake and exaust valve
Ajc logging
10-02-2006 19:07:02
Just done a overhaul on a 8n I put the head back on getting water out of # 4 intake and exaust valve have used two diffrent head gaskets still doing it wondering if it might be head warped or could it be somthing else
Joe (IN)
10-02-2006 19:47:29
 Re: Water coming out of intake and exaust valve in reply to Ajc logging, 10-02-2006 19:07:02
Head cracked
block cracked
block deck warped
head warped
improper torque spec
incorrect fastener type
bad head gasket
leaking manifold stud
Joe (IN)
10-02-2006 19:49:09
 Re: Water coming out of intake and exaust valve in reply to Joe (IN), 10-02-2006 19:47:29
And last but not least, if you've been using all metal head gaskets, switch to the non-metal kind.
Bob
10-02-2006 21:06:44
 Re: Water coming out of intake and exaust valve in reply to Joe (IN), 10-02-2006 19:49:09
OR.... Simply spray several coats of cheap aluminum spray paint, or a commercial product, such as Copper Kote, on each side of the metal head hasket, allowing each coat to dry, before installing the metal-clad head gasket.
