I have a 1952 8N that is still 6 VDC with a side mount distributor. I am having trouble getting the tractor to idle. I can only get the rpm's down to 550-600 for a steady operation. Much below and it spits/sputters and dies (can't get anywhere near the recommended 400 rpm). Also, no matter if the engine's cold or at operating temp. I always have to choke it to start.Here's what I've done: rebuilt carb., new points/condenser, new spark plugs, new ignition wires, new battery, new wiring harness (connections verified by OEM wiring diagram), cleaned air filter, cleaned fuel sediment bowl, removed gas tank and cleaned, removed intake/exhaust manifold and cleaned and leak tested after mounting, new proof meter. All the above new material was bought at a New Holland store as OEM. I've set the power mixture screw, then lowered the idle speed screw on the carb. However the idle mixture adjustment screw seems to have no affect at idle if I set it or bottom it out (550-600 rpm is as low as I can go). It does speed up if I completely remove the needle (throttle lever at same position). Please let me know what I'm missing. Thanks much.
