Order Ford 9N Parts Online
9N backfiring and popping
reddogge
10-05-2006 15:43:34
Fellow sufferers,
I've had a love/hate relationship with my 1940 9N for 17 years and it threatens my sanity and marriage. It has been backfiring and popping lately showing a lack of power and cutting out on a hard turn or pull. I clean the carb filter and sediment bowl each time thinking that is the problem. It has a new carb, distributor, plugs, wires, generator. I've spent a fortune on it the last two or three years. Don't know if it is timing, fuel, carb, ignition at this point.
Help!
Popster
10-05-2006 19:37:54
 Re: 9N backfiring and popping in reply to reddogge, 10-05-2006 15:43:34
Could the problem on the turn be caused by distributer being hit due to worn kingpin?
Bob Harvey
10-05-2006 18:59:24
Could be : 1. Bad plug (s)..a lot are being made offshore 2. Bad plug wires....same reason 3. Intake leak, manifold (left side looking at the manifold) 4. ANYTHING else, moisture is a BIG issue.
reddogge
10-06-2006 08:52:19
 Re: 9N backfiring and popping in reply to Bob Harvey, 10-05-2006 18:59:24
Bob,
I do seem to have a leak in the manifold on the left side but it seems to be up around the exhaust side. Would the fix be to pull it off and put new gasket on it?
Thanks,
Richard
RP-40-9n
10-05-2006 16:50:28
red, looks like we suffer the same fate, but ive only been infected for 4 months with my 9n. but i have to say she's really gettin after it right now. from the info you gave, i would suspect sticking valves or a governor getting bad, or possibly bad or loose carb or manifold gasket. good luck RP
