Low Compression and Oil in Radiator
Ole in Wisconsi
05-21-2001 13:04:51
Just brought home my 49 8N. Dry compression check found #4 at 65psi, #3 at 85psi, #2 at 85psi and #4 at "0". Also, inspection of anti freeze found engine oil floating on the surface of the filler neck. Tractor starts and runs (no load) great. Oil level good as is anti freeze level. Slightly opening pan drain found oil comming out and no water. Is it about time for a rebuild? No compression probably a valve issue. Oil in radiator worries me. Any idea's would be much help.
Snowplow
05-21-2001 17:52:39
 Re: Low Compression and Oil in Radiator in reply to Ole in Wisconsin, 05-21-2001 13:04:51
Oil in the radiator is probably from a head gasket blow out, which may also effect your compression, esp. the dead one.
Ole in Wisconsin
05-22-2001 10:24:04
 Re: Re: Low Compression and Oil in Radiator in reply to Snowplow, 05-21-2001 17:52:39
Thanks for the tip. Hard to believe these things can still run well on only 3 cylinders.
buck
05-21-2001 14:18:08
would suggest adjusting the valves and see what happens. Wouldn't be to concerned about the oil in radiator.
