Height of top link
phil_in_wa
10-06-2006 20:25:39
Working on welding up a custom boom pole lift.
What is the height of the bottom of the 3 top link pins from the ground. Aprox is fine.
Alas I'm 300mi from my '49 8N
Thanks as alwasy
Bruce (VA)
10-07-2006 06:03:26
 Re: Height of top link in reply to phil_in_wa, 10-06-2006 20:25:39
I'm about 10 feet from my 51! According to my trusty tape measure, the center of the bottom top-link pin hole is 32 inches off of the garage floor..... which is not a lot less than waist high to me, as I am "vertically challenged!"
Marty 2N IL
10-07-2006 03:47:18
third party image
Here is a boom pole I welded up with a extra cylinder to lift. You can also extend it out. I built it for a diffent tractor than the 2N with aux hydulics. I would have used a pump jack if for the 2N but the front gets a little light.
I think my top link is about 42" form the ground. If I remember right I think I made the three point on my hitch 22" wide and 32" high but I not for sure and I am about thirty miles from mine.
Marty
gahorN
10-07-2006 02:48:09
'bout waist-high. (grin...you said approx was fine!) (I'm about 200 mi. away from mine too.) ;Þ
