Order Ford 8N Parts Online
8N serial number
Olde World Acre
10-12-2006 11:26:13
I have an 8N that has a rather strange serial number sequence on the engine. From what I can see it says 8N10056# I realize that this probably isn't right, but is it possible? Has anyone run across anything similar?
Is there another area that the same serial number should be? I thought that there should be one on the back axle but I don't seem to see anything. I need to get parts for it, and want to make sure that I get the right ones since everything is based on year which is based on serial #. Unless of course you are lucky enough to have the original paperwork!
Thanks,
Chuck
Bruce (VA)
10-12-2006 15:34:49
 Re: 8N serial number in reply to Olde World Acres, 10-12-2006 11:26:13
In addition to the rear axle & pump base, casting dates are often found on the block just behind the starter, on the bottom of the oil pan and on the tranny.
souNdguy
10-12-2006 12:16:23
Verify the casting dates on the axles to see if they sort of match the engine date. engines get swapped around alot. Also.. to verify that you are reading the engine# right.. it should be a front mount distrib.
Soundguy
olde World Acres
10-12-2006 12:29:44
 Re: 8N serial number in reply to souNdguy, 10-12-2006 12:16:23
It is a front mount distributor.
I will check on the axle casting dates.
thanks,
Chuck
Dan 2N
10-12-2006 11:53:10
That number is for a 1947 8N, that no. is not on any other place but there are casting dates on most housings and the bottom of the hydro pump.
Dan 2N
