2N steering box leak
5NSlezWI
10-13-2006 13:07:10
I have seen previous posts that corn head grease works well for dealing with steering box leaks. I"d like to try this on my 2N. How do I drain any remaining oil and refill with the corn head grease? There doesn"t seem to be any drain or filler holes.
Thanks!
Slez
5NSlezWI
10-13-2006 18:25:06
 Re: 2N steering box leak in reply to 5NSlezWI, 10-13-2006 13:07:10
Just a follow up question...
Is the Packing, part #9N3670, that is available on this site what I need to fix the leak?
Thanks again!
Dell (WA)
10-13-2006 20:11:00
 Re: 2N steering box leak in reply to 5NSlezWI, 10-13-2006 18:25:06
Sleezy..... ...yep, thems the seals. p/n: 9N3670. I can't remember wheather felt or rope. $3.50ea (cheap) Lets hope you don't need to replace the bushings. Go for the cheap and eazy fix. And iff'n it don't stop yer leaks then guess what? Its the harder stuff..... ...Dell
5NSlezWI
10-13-2006 18:16:38
Dissappointing indeed! I was looking for the easy fix. I guess it's time to split the steering box.
Dell (WA)
10-13-2006 13:20:03
Sleezy..... ....unfortunately, the 2N/9N steering gearbox is "splash-lubed" by the tranny front bearing oil-slinger with hydro-tranny oil.
You CAN-NOT use sticky cornhead oil with the 2n/9N steering gears. Understand?..... ...Dell
