PTO shaft question......
Poot
10-17-2006 09:44:37
I have two 8Ns. a `48 & a `50. I went to clean the PTO shafts & found that by turning the shaft CCW on the `50; the arms will raise. It doesn't do that on the`48. Any thoughts?
souNdguy
10-17-2006 11:38:32
 Re: PTO shaft question...... in reply to Poot, 10-17-2006 09:44:37
That's the method i use to test N 3pt hyds when I stop and look at one by the roadside. Control lever up, pto disengaged, spin the shaft. if the arms bob up.. hyds are pretty good.
Soundguy
DON TX
10-17-2006 15:05:21
 Re: PTO shaft question...... in reply to souNdguy, 10-17-2006 11:38:32
PTO disengaged??? Doesn't the PTO have to be engaged to work the pump? DON TX
souNdguy
10-18-2006 05:27:25
 Re: PTO shaft question...... in reply to DON TX, 10-17-2006 15:05:21
Pto disengaged so I don't have to turn the countershaft and all the gears in the tranny by hand. The pto engage / disengage lever couples the pto shaft to the back of the tranny.. the shaft then goes thru the pump. Bottom line.. if the pto shaft turns.. the pump pumps.. Don't matter if it is by hand or by tranny. There is no way to disengage the pto shaft from the pump, except by pulling it.. thus it is always coupled.. thus if the pto spins, the pump pumps.. etc.
Soundguy
murnga
10-17-2006 15:51:29
Not if you turn the shaft at the rear of the tractor.
Bob
10-17-2006 09:55:21
Surprisingly, these pumps will pump either way you turn the PTO shaft, as it is a twin-piston pump diven by Scotch yokes... it is NOT direction-sensitive.
The one that DOESN'T lift must be more worn and/or have more leakage in the pump, valves, or cylinder, allowing the small amount of oil you are pumping turning it by hand to leak off, rather than making the lift go up.
Poot
10-17-2006 19:07:26
 Bob...... in reply to Bob, 10-17-2006 09:55:21
both of the PTO's only turn one way, CCW. If I turn them CW, I get a ratcheting sound.
Sam#3
10-17-2006 19:18:35
 Re: Bob...... in reply to Poot, 10-17-2006 19:07:26
Do you have ORCs?
Poot
10-17-2006 20:41:11
 Well, I dunno Sam....... in reply to Sam#3, 10-17-2006 19:18:35
I'm new at tractors. Is the ratcheting sound I hear, what an ORC sounds like?
Sam#3
10-17-2006 21:01:06
 Re: Well, I dunno Sam....... in reply to Poot, 10-17-2006 20:41:11
Like a ratchet. An Over Running Coupler is placed on the end of the PTO shaft. It's a big hunk of iron usually with a grease fitting protruding from each side. If it's there you can't miss it.
Poot
10-17-2006 21:05:36
 Re: Well, I dunno Sam....... in reply to Sam#3, 10-17-2006 21:01:06
A grease fitting on one side & a set screw on the other, perhaps?
Sam#3
10-17-2006 21:13:09
 Re: Well, I dunno Sam....... in reply to Poot, 10-17-2006 21:05:36
Could be.
Poot
10-17-2006 21:21:50
 Re: Well, I dunno Sam....... in reply to Sam#3, 10-17-2006 21:13:09
I hope so. I hear an ORC is a good thing to have.
Thanx, Sam
Sam#3
10-17-2006 21:30:50
 Re: Well, I dunno Sam....... in reply to Poot, 10-17-2006 21:21:50
They've saved many fenders and fences.
Be safe, Sam
jmixigo
10-17-2006 11:11:41
 Re: PTO shaft question...... in reply to Bob, 10-17-2006 09:55:21
Or you mite have the controll lever set different?
Poot
10-17-2006 20:44:36
 Nope...... in reply to jmixigo, 10-17-2006 11:11:41
the controls are set in the same position on both tractors.
