Compression
Ardie Dedrickso
10-17-2006 17:32:11
I've looked all over but can't find what the compression should be on 2N, 8N and 9N Fords. Thanks for your help.
Bruce (VA)
10-17-2006 17:41:50
 Re: Compression in reply to Ardie Dedrickson, 10-17-2006 17:32:11
130 is about as good as it gets. 90 is the minimum, with the lowest reading w/in 75% of the highest. Check out tip # 46 to make a compression check easier:
http://www.ytmag.com/articles/artint268.htm
Dell (WA)
10-17-2006 17:41:29
Ardie..... ...Ford compression specs: 90psi min (dry). These low compression flatheads don't test very high. A new engine will test about 120psi. My 1969 BMW tests about 165psi..... ..Dell
