Order Ford 8N Parts Online
8n quits
Rogar Lipe
10-17-2006 19:33:44
Why is it that my 8n quits after running for a short time?, Carb need rebuilding?
jethro1
10-18-2006 06:00:10
 Re: 8n quits in reply to Rogar Lipe, 10-17-2006 19:33:44
i suspect a clogged or restricted fuel line
old
10-17-2006 20:05:04
Lot more info need to answer your question. Front or side mount? when it dies doe it have spark?? If it has spark is it a brite blue or a yellow looking spark?? Do you have a good gas flow out of the drain plug on the bottom of the carb??
Dell (WA)
10-17-2006 20:04:13
Lipe..... ...ya don't give us much to guess on do you? Define "running for short time." 10yr ago, one of the founding members of this great N-Board, insisted 80% of all carburator problems were found in the ignition system. Me? I'd guess weaksister ignition switch. $10 (cheap)..... .respectfully, Dell
DON TX
10-17-2006 19:45:27
Here is a link to check for your problem. It's under "Research and Info" on the left of the page. If you don't get results give us more info and you'll get plenty of help. The more info the better. HTH
DON TX
jmixigo
10-17-2006 19:48:16
 Re: 8n quits in reply to DON TX, 10-17-2006 19:45:27
Thats way better than that easy button on TV.
