Order Ford 8N Parts Online
positive ground 8n, negative ground log splitter
Old_School_Nut
10-20-2006 08:50:12
Hello guys, I have a 1949 8n with a 6v positive ground system. However I want to pull a log splitter with a 12 volt negative ground OR 12 volt positive ground electrical system on it (I don’t know yet what it is other than its 12 volt), will I run into problems? Also, out of curiosity, how about if it was a 6 volt negative ground?
thanks guys!
Old_School_Nut
10-20-2006 10:07:40
 Re: positive ground 8n, negative ground log splitt in reply to Old_School_Nut, 10-20-2006 08:50:12
great! thanks for the good news guys!
looks like its time to split some wood!
Old_School_Nut
10-25-2006 07:30:44
 Re: positive ground 8n, negative ground log splitt in reply to Old_School_Nut, 10-20-2006 10:07:40
third party image
here is a pic of my 8n and a friends H that i was working on...
old
10-20-2006 10:02:13
As long as your useing 2 batterys and the only point of hook up is the hitch you have no problems. But it you start hooking up wires from one to the other then you may have a problem
Joe (IN)
10-20-2006 13:43:06
 Re: positive ground 8n, negative ground log splitt in reply to old, 10-20-2006 10:02:13
Isn't that what I just said?
old
10-20-2006 16:11:47
 Re: positive ground 8n, negative ground log splitt in reply to Joe (IN), 10-20-2006 13:43:06
Yes sort of but haveing more then one person say the same thing in another way always seems to help get the point through
Joe (IN)
10-21-2006 07:55:21
 Re: positive ground 8n, negative ground log splitt in reply to old, 10-20-2006 16:11:47
Ah, I see. So are you insinuating that an answer only gains credibility after YOU'VE acknowledged it or that I personally lack credibility and MY answers need to be independently verified?
old
10-21-2006 08:03:26
 Re: positive ground 8n, negative ground log splitt in reply to Joe (IN), 10-21-2006 07:55:21
Well I guess thats a yes, no and sort of thing. I've just found at time people want to here from more then one person when they ask a question so some times I will post just to make sure the person understands. Of course some time just one post is ok also. If I had a $1 for every time some one posted the same thing I said I would have enough money to keep me in beeer for the next year or 2 LOL
Joe (IN)
10-20-2006 09:05:27
Different ground polarities and voltages aren't an issue unless other wiring between the two systems is intermixed. Go split some wood!
