FOUND: elusive bowl vent [Marvel carb]
John Sugden
10-21-2006 18:07:59
With reading about the bowl vent in the Marvel carbs, but never having a definate location for it I went on a hunt. I searched every page I could find on these carbs, I finally went to a guy not too far away and sat and talked with him about this carb. He told me the bowl vent is the rectagular hole in the end of the bowl which mates to the same shape and size hole in the top half of the carb. I looked at two different carbs and mine on the ford looks like it dead ends in the top half of the carb, but it does go through with two small holes. One hole comes out above the throttle plate and the second larger hole comes out below the throttle plate. Mine was clear so this wasn't my carb problem, I rebuilt the carb again with a kit from my local NAPA store and changed the float level from 1/4" to 3/4" and it runs fine now. Still can't turn the screw in where the books say it should be but at least I can screw it in part of the way now. At this point I can run the tractor and any RPM range without popping through the carb and don't have to worry about dirt getting in the open hole in top of the carb. So this vent does exist and now I know where it is and where it goes to.
ZANE
10-23-2006 04:39:25
 Re: FOUND: elusive bowl vent [Marvel carb] in reply to John Sugden, 10-21-2006 18:07:59
There is another condition that can prevent the gasoline from being drawn/pushed into the low pressure air stream in the venturi area of the carburetor even if the vent passages are clear and open and that is if the sealing around the top and bottom of the venturi is not suffecient to prevent too much of a vacuum for the vents to carry it all. When the venturi leaks enough it will allow the carburetor bowl area to become equal in vacuum pressure as the intake venturi area and when this condition is reached there is no barometric higher pressure in the bowl to push the fuel/gasoline into the venturi area. Actually the barometric pressure is what injects the fuel/gasoline into the intake when the intake pressure is lower than the bowl outside/barometric air pressure in the bowl area.
So make sure the venturi is not bent or that the gasket is not damaged or out of place so that the venturi is sealed top and bottom when the two halves are mated together.
Ken S.
10-22-2006 11:11:58
I&T FO 4, fig.50 clearly shows the bowl vent and Paragraph #50 clearly explains it"s operation. WHAT"S THE BIG MYSTERY????
uh . . . Dell (WA)
10-22-2006 17:52:01
 Re: FOUND: elusive bowl vent [Marvel carb] in reply to Ken S., 10-22-2006 11:11:58
Ken..... ..all carb drawings LIE; and thats the truth.
I've worked on a number of different makes and designs of carbs and there is always a puzzlement about where some bleed-jets are in the real world..... ...Dell
Ken S.
10-22-2006 18:58:26
 Uh Dell, in reply to uh . . . Dell (WA), 10-22-2006 17:52:01
All carb drawings LIE?
Dell, All the makes and models of carbs you have worked on don't mean beans, the fact is the FO 4 fig. 50 drawing shows how the bowl is vented, just like Bob said it is, and just like my real world carb. is. If you disagree, show us how FO 4 is wrong, rather than generalize about "makes and models".
Dell (WA)
10-22-2006 22:43:16
 Re: Uh Dell, in reply to Ken S. , 10-22-2006 18:58:26
Ken..... ..you deliberately miss-understood my statement and challenged me to correct the carb drawing. It ain't gonnna happen because the bowl vent is there just as the drawing alludes. It just ain't where the drawing implies it should be. That is why I said all carb drawings "LIE".
I have in my lifetime rebuilt many different makes and types of carbs and I have found it takes some imagination to match the real-world with the drawing. Has to do with trying to depict 360deg spatial locations in 180deg flatsheet..... ...respectfully, Dell, former aerospace draftsman
Bob
10-22-2006 12:33:14
Ken,
I guess you didn't realize there are a LOT of different "FO-4's" out here, depending upon when they were published.
For instance, mine (which has been around a while, since it caries a list price of $4.00), says very little about the carburetor, covering it in only ONE paragraph, Paragraph 42.
There are NO illustrations of the carburetor in the issue of the FO-4 I have.
Paragraph 50 covers the GENERATOR and photo 52 is of 9N and 2N gear shift rails!
Quite a difference between issues of the manual!
I will try to get the carb photos I have posted soon. The 'puter I normally use for photo work puked it's harddrive, and I have to install a new one and load the OS and photo software before I can post the photos.
Hobo,NC
10-22-2006 14:36:02
 Re: FOUND: elusive bowl vent [Marvel carb] in reply to Bob, 10-22-2006 12:33:14
Gotta git ya a new FO-4 as ken has posted it shows a good pix and description.
Bob
10-22-2006 17:26:23
 Re: FOUND: elusive bowl vent [Marvel carb] in reply to Hobo,NC, 10-22-2006 14:36:02
I DON'T need a new FO-4, 'cause I know where the darn bowl vent is.
My point was, I'll bet there's LOTS of other older manuals out that that folks are looking at, and I was bringing up the point they're NOT all alike!
Ken S.
10-22-2006 19:08:06
 Re: FOUND: elusive bowl vent [Marvel carb] in reply to Bob, 10-22-2006 17:26:23
Bob,You clearly don't need a new copy of the FO 4, however the starter of this thread and some responders clearly DO need a new copy. Anyone who opens one of these VERY simple carbs up should be able to find the bowl vent. If they can't they have no business working on them. IMHO
ron,ar
10-22-2006 20:27:48
 getting testy aren't we ken? in reply to Ken S. , 10-22-2006 19:08:06
"Anyone who opens one of these VERY simple carbs up should be able to find the bowl vent. If they can"t they have no business working on them. IMHO
Actually Ken, I suppose I opened this thread, or more precisly, this subject over on page two, when I called this vent "the elusive bowl vent". I don"t owe you an explanation but since you have gotten your britches all wadded up, here goes the long story. I got this tractor in June, it had sat up a long time. I re-wired it, did a tune-up, switched it to 12 volt,vatted the carb and put a TSC kit in it, after blowing it out with compressed air. I set the two adjusting needles as advised on this board and in my older FO4 manual. It started right up, idled fair but would not throttle up correctly without the high speed needle out 6-8 rounds. That in it self didn"t bother me too much except that it would sputter when under load if the fuel lever was at WOT. If I backed the lever down about 1/2 inch it smoothed out.I bought a new bucket of carb cleaner and boiled it out again. I blew it out good, ran a fine wire everywhere I could see to run one. Everywhere I blew air into I got return somewhere. After re assembling it again the problem was still there. I checked the distributor for correct point setting, made sure I had the right screws in the right place, checked for slack in the dist bushing. Everything looked good. It still did not run to suit me under load. I left the four screws a bit loose between the two halves and it did help. This led me and others on this board to think that the bowl was not venting which would cause poor fuel flow (if air can"t get out, fuel cannot enter the bowl). The float is set right and I did try changing the float level a tad each way. BTW-the compression is a litle over 100 psi on each cyl. Everyone here agreed the bowl vent had to be plugged. When I started asking the exact location of this vent, I recieved numerous replies, but they were as different as day and night. Not one reply back then posted an accurate picture or drawing of this vent. I tried Zanes trick of drilling a small hole in the top of the housing which helped a great deal but it is still not exactly right.I tinkered with the timing also which did not solve the problem. I am no novice to mechanical devices, am 58 yrs old, have been working as a mechanic since I was a young man (19) and am Ford and ASE certified
medium/heavy diesel tech. I like things to work right, and when they don"t I want to know why they don"t. Yes, this is a simple carb, espically when compared to say, a GM Quardajet or a Ford Varible Venturi, but that does not mean folks should get upset with others over it. I know fully well that I can order another carb but I want to fix this one, it is almost surely the original. I have kept all the old wiring and generator/regulator and plan on re-installing it at a later date. HOBO has posted a drawing on his site but it is in PDF format and as I have said this old computer has a small hard drive and only 28 MB ram, so I cannot install Acrobat Reader and open his site. I will do that tomorrow at work tho. Bob has been very helpful and has promised to post an accurate drawing also. We live in a small town with no local tractor shop, so no other FO4 manual is close by. I will order another one but had hoped to get this resolved this weekend. I apologize if this MINOR carb malfunction has ruined your weekend to the point you feel you have to get testy about it. From now on if you see a post with my name on it, please refrain from opening it as it may also cause you much anguish, and could result in high blood pressure and/or stroke or heart attack. If you wil post your whereabouts we will call ahead before we post again and have 911 send paramedics to your home just in case. :^)
Bob
10-21-2006 21:36:51
 John.. Bowl vent horse pucky... in reply to John Sugden, 10-21-2006 18:07:59
John,
You say "but it does go through with two small holes. One hole comes out above the throttle plate and the second larger hole comes out below the throttle plate."
HORSEPUCKY!!!
The holes above and below the throttle plate are the holes where the IDLE MIXTURE discharges into the engine's intake air stream.
The hole ABOVE the throttle plate is where the idle mixture discharges into the airstream at idle, the hole just below the throttle plate is sort of a "transfer passage" that begins to discharge fuel as the throttle opens, BEFORE the "load circuit" kicks in, to avoid "stumble" as the throttle opens.
The bowl vent is as follows:
There are 4 holes in the carb gasket, leading to 2 chambers ABOVE the gasket, left and right. From the 2 chambers ABOVE the gasket, there are 2 holes drilled into a common passage that leads to 2 holes that exit into the chamber SURROUNDING the venturi. The venturi is sealed at it's top and bottom, to the carburetor's top and bottom casting, isolating the air flow (and suction) inside the venturi from the VENT passage OUTSIDE the venturi.
This area SURROUNDING the venturi is upen to the rectangular port in the gasket that matches up with the rectangular hole in the lower carb casting that leads to the carb inlet area, at the top of the air inlet port in the LOWER carb casting, ABOVE the choke plate area.
Also, the air for the idle circuit is sourced from that same common area surrounding the venturi.
There is a drilled passage from the vent area up to the backwards-acting idle mixture screw.
As the idle mixture screw is OPENED, it allows MORE air from the vent area to flow INTO the idle mixture, LEANING it out.
I have several photos showing the vent circuit threaded with RED insulated wire though the passages, to make it easy to see. Within the next day or so, when I have a few minutes, I will resize them, and post them, HOPEFULLY clearing up "the elusive vent passage mystery" once and for all!
Phil (NJ,AZ,SasK)
10-22-2006 12:45:53
 Re: John.. Bowl vent horse pucky... in reply to Bob, 10-21-2006 21:36:51
BOB, You need to hi-light the fact that this is the "Source" of AIR, Post Filter.
Regards,
Bob
10-22-2006 12:51:01
 Re: John.. Bowl vent horse pucky... in reply to Phil (NJ,AZ,SasK), 10-22-2006 12:45:53
Yeah, when I get the other 'puter up and running, I'll annotate the photos, before posting.
Do you agree with my discription of the "idle" and "transfer" passages?
Regards,
Bob
Phil (Nj,Az,SasK)
10-23-2006 01:47:20
 Re: John.. Bowl vent horse pucky... in reply to Bob, 10-22-2006 12:51:01
[quote]Do you agree with my discription of the "idle" and "transfer" passages?[/quote]
Yes! also the air venting into the main Jet Nozzle cavity, acts like an accelerator pump, is an interesting feature.
Note: The Float Specifications are that the Wings are Bent such that the 1/4" distance is constant and results in the float been Parallel to the Upper Assembly. Therefore Max. Displacement. I think most PPl, & myself, just bent the contact Tab & that results in float Tilt (front to back)
JMHO
ron,ar
10-22-2006 00:28:51
 thank you in reply to Bob, 10-21-2006 21:36:51
The real problem as I see it is that this "bowl vent" is percieved as a simple air passage as almost just an opening in the upper carb bowl. I keep referring to this as "the elusive bowl vent" because I have asked several times since June for a good picture/drawing and you can see how many different opinions/ ideas have been posted. My only consolation is that I am obviously not the only one having problems with this air passage. Lately I have seen a couple of cross section drawings of this "vent". It does far more than just allow the air out of the top of the float bowl as fuel enters but that is the part that causes the greatest problems in the main jet circuit. Drilling a hole in the top only helps, but does not cure the problem (or symptom) of a stumble when at full throttle, with a seemingly "unadjustable" main jet screw. Most of the time it causes the main jet adjusting screw to have to be screwed almost all the way to run at full throttle. Most folks think because they vat the carb, blow it out good and air comes out "SOMEWHERE" from each orfice that all passages are open. As you have stated, that circuit is a little more complex than "air in-air out". Another problem stems from the use of terms. Low speed jet/high speed jet, fast idle adjusting needle/ high speed needle/main adjusting needle, idle mixture screw/main mixture screw etc. etc. These terms are all used interchangably in different publications. Heck, only the people on these pages understand what you mean when you say "backward acting idle mixture screw:^) And to complicate matters more are manufacturers terms...I have seen several governors and their accompaning literature refer to "low idle" and "high idle" adjustments. Some of us know the difference but too many people equate the term "IDLE" to low speed only. I am looking forward to your photos, and again, thank you for your help/advice.
ron,ar
10-21-2006 20:25:07
 explain please in reply to John Sugden, 10-21-2006 18:07:59
third party image
Are you referring to the rectangular hole in this picture which is marked "main Jet" (incorrectly)?
Or to the almost oval shaped indention to the right of that hole in this picture? Hobo's link below under "carb tips" does show a drawing of the vent and passages but I cannot post nor open that picture because I do not have Adobe Reader as I do not have room for it on this particular computer. You can scroll down to the "elusive Bowl Vent" thread below and click on Hobo's reply and see it on his site.
Bob
10-21-2006 21:39:08
 Re: explain please in reply to ron,ar, 10-21-2006 20:25:07
SOMEBODY needs to fix that stupid picture showing the main jet inside that rectangular hole!
There ain't nothin' down there but the choke plate, and AIR!
Marty 2N IL
10-21-2006 19:47:51
Any Pictures?????
Ron,ar
10-21-2006 18:58:47
I'm confused :^)
