Center Link
Ande
10-24-2006 05:15:27
Wandering if anyone knows of what the original center link on the 3 pt of a 8N 1948 model would look like.Is there any pictures in here? Also is there any available and what cost.Would like to keep this 8N as original as possible.Mine was missing when I bought the tractor
Ande
lonestarjeff
10-24-2006 19:47:56
 Re: Center Link in reply to Ande, 10-24-2006 05:15:27
Ande...there were actually 3 or 4 different versions of the toplink issued w/ the 9N, & later the 2N & 8N(I recently learned this). The differences had to do w/ the number of adjustment holes, slots, etc.
Jeff
mn.Chuck
10-24-2006 07:43:10
I do have a original top link(2 halves bolted
together)Intact but wear at the ball ends and a
chip out. Has the straps for depth stop on the old 14-1 etc mowers but a couple "hooks" broken
out. $ 18 plus some postage. Also have a '50-60's
original with lock attached. $ ?. Also have a
new end w/ lock for one of these. Thanks, Chuck
Dan
10-24-2006 05:44:34
third party image
Are you talking about the bar like this, or the rocker where this bar attaches to the tractor. Here is a pic of my original top link I refirbished for my 1948 8N trailer queen.
Dan
Ande
10-24-2006 17:46:57
 Re: Center Link in reply to Dan, 10-24-2006 05:44:34
Dan
Gee to me that looks like one of the 3 point arms (2 of them) I was in need of the center link or arm that hooks in the middle to the implement,or is this what a 48 8N middle link is suppose to look like?I bet your Ford looks sharp.
Carl S in NH
10-24-2006 06:12:54
Dan, is that a single non adjustable bar or two pieces that can slide past each other to allow for length adjustment? My 8N came with the new double ended threaded links which are more or less infinitely adjustable so I have no experience with the older, original type. I'm just wondering because some day I might run across one of these originals at a barn or estate sale and if I knew what it was, I'd pick one up. Oh and btw, I've been following your engine rebuild problems on the "other" forum. But I think there are lots of interested people here that would like to know about how your machinist "stitched" that block you bought. Maybe you could post those pics here?? Anyway, good luck and hope you don't encounter any more problems.
Carl
Dan
10-24-2006 06:19:56
 Re: Center Link in reply to Carl S in NH, 10-24-2006 06:12:54
This top link is actually two bars bolted together. There is a slot so the bars can slide some for adjustment, but there is not a lot of adjustment you can do. Mine was missing the "Y" shaped chain and I will fabricate one to hold the rocker pin and lynch pin. The ball ends on this one was in great shape, so I lucked out there.
As far as posting here, I felt I was burning the members out here with my usual contant questions, so I decided to move to the "other" board for awhile and give the users here a break :-)
Dan
Ande
10-24-2006 17:36:33
 Re: Center Link in reply to Dan, 10-24-2006 06:19:56
Dan
I know the feeling,but everyone seems so helpful,sure makes working on the Fords fun! Thanks for your post
