Knocking hydraulic pump. Why does this happen.
Pooh Bear
10-24-2006 07:33:21
Ok, I know these old scotch yoke hydraulic pumps
can have a little bit of knock to them.
Mine is fairly quiet, until.....
If I raise the lift all the way up with a heavy
implement on the back when it gets to the top
it knocks a lot louder. If I just bump the touch
control lever forward a bit it goes back to quiet.
It is quiet enough that if nobody ever told me I
probably would have never noticed any knock at all.
But at the top with a load, that is noticable.
Just curious as to why it happens that way.
Thanks.
Pooh Bear
Dean
10-24-2006 08:07:18
 Re: Knocking hydraulic pump. Why does this happen in reply to Pooh Bear, 10-24-2006 07:33:21
Pooh:
It sounds like your touch control mechanism is a bit out of adjustment causing the system to relief via the relief valve when the cylinder dead heads at the end of travel. This causes the pressure to rise to the relief valve setting. You can verify this by chaining the lift arms down and raising the quadrant lever. I suspect the knock will inicrease just as it now does at the top of travel.
You could go completely through the lift adjustments to repair this but it is much easier to set the lift control lever top stop below the point where this occurs.
Dean
Pooh Bear
10-24-2006 16:03:24
 Re: Knocking hydraulic pump. Why does this happen in reply to Dean, 10-24-2006 08:07:18
My lift controls definitely need adjusting.
Only about the top 2 inches do anything.
And this is an 8N in Position Control mode (lever up).
Just not a job I'm looking forward to doing.
Thanks.
Pooh Bear
Dean
10-24-2006 16:30:12
 Re: Knocking hydraulic pump. Why does this happen in reply to Pooh Bear, 10-24-2006 16:03:24
Pooh:
It is a pretty straight forward job if you have a fixture like Zane sells to set the adjustments. It is a frustrating, time consuming, two man job without one.
Dean
Pooh Bear
10-24-2006 19:36:18
 Re: Knocking hydraulic pump. Why does this happen in reply to Dean, 10-24-2006 16:30:12
I've got Zane's jig on my Christmas wish list.
Pooh Bear
Dean
10-25-2006 05:26:25
 Re: Knocking hydraulic pump. Why does this happen in reply to Pooh Bear, 10-24-2006 19:36:18
Here's hoping that Santa is good to you.
I have had one for over a year but have not yet found the time to go through my 51 8N again. Maybe this winter?
Dean
