Bent left lift rod
Richard Fazio
05-23-2001 03:54:33
I have this left lit rod on my 2N that is bent. It's got a nice curve to it. Probably happened when someone backed into something. I would like to straighten it out. Should I heat it up and straighten it or will it loose it's temper or something and get weak? Thanks.
bj/8N/mt
05-23-2001 05:35:06
 Re: Bent left lift rod in reply to Richard Fazio, 05-23-2001 03:54:33
I have straightned bent radius rods with the following method and don't see why it wouldn't do the job on lift arms:
Get a railroad tie, get a couple of four by four blocks, get a come along or a chain hoist, use the four by fours to hold the strain off the ends, wrap the chain/wire rope around the bent item and the tie--pull it back straight keeping well out of the line of fire should something give way
Your mileage may vary
DaBrow
05-23-2001 13:53:14
 Re: Re: Bent left lift rod in reply to bj/8N/mt, 05-23-2001 05:35:06
I prefer to straighten radius rods off of the tractor in a 25T press. Correct support blocks used of course....DaBrow.
