Jubilee PTO shield
Paul Schultz
10-29-2006 14:49:14
So, in the next week or so I'll get a replacement PTO shaft to connect my recently purchased Ford Series 909 rotary cutter to my Jubilee.
In my 1.5 years as a Ford tractor owner I haven't used the PTO and have read quite a bit ...especially regarding safety issues.
One item is a PTO shield that attaches to the back of the tractor and acts as a 'hood' over the PTO. I like this idea but was wondering if any parts vendor sells one for the Jubilee? After all, the rotary cutter has a shield for the implement end of the PTO shaft it seems I should have one on the tractor end!
TIA,
Paul.
souNdguy
10-30-2006 07:02:01
 Re: Jubilee PTO shield in reply to Paul Schultz, 10-29-2006 14:49:14
Take a 6" pipe, cut a 6" - 8" piece.. cut a portion of the side wall out.. make this the bottom. ( from the end it looks like a 'C' with the opeing facing down... ) Weld ears/tabs to one open side, drill the ears/tabs to accept the bolts around your pto bearing carrier.
Soundguy
jimNCal
10-29-2006 20:09:56
Check eBay. I work in sheet metal and could make a bunch of them if I could ever find the time. Waiting on me would not be a great idea. Seems that the day job gets in the way of tractor time.
jim
