Loss of Power
ORHotrod
10-29-2006 22:59:31
Please Help me... I'm new to the 8N world. My 8N seems to have lost power I'm working on 2 acre piece of ground plowing, discing and hauling rock out. Yesterday it started blowing water out the radiator cap. Today there is a noticeable loss of power with a small puff of white smoke out tailpipe when started. I recently replaced the exhaust manifold as old one was broken. Don't really known what the problem is but I'm thinking headgasket..
souNdguy
10-30-2006 05:19:02
 Re: Loss of Power in reply to ORHotrod, 10-29-2006 22:59:31
Check oil fro water and water for oil.
If you did pop a headgasket you may be venting combustion gasses into the radiator.. dumping the water out.
Also.. the studs for the e-manifold are wet AFAIK.
investigate and post results back.
Soundguy
ORHotrod
11-02-2006 13:48:03
 Re: Loss of Power in reply to souNdguy, 10-30-2006 05:19:02
By the way souNdguy thank's for your reply. The bolt that was oily was head bolt #16
ORHotrod
11-02-2006 13:12:39
Drained radiator and oil pan. No oil in water but oil looked like chocolate milk. Pulled Head had large blow out between 1 and 2. I have another question. One head bolt was very oily when I pulled the head. Is this a sign of cracked block???
souNdguy
11-02-2006 20:41:39
 Re: Loss of Power in reply to ORHotrod, 11-02-2006 13:12:39
Some head bolts are blind.. some are not.
If you didn't see oil in the water, and you had good oil pressure, then i wouldn't think too much about a greasy headbolt. If it really bothers you.. put some thread pucky on it when you reinsert it.
Soundguy
ORHotrod
11-02-2006 21:08:24
 Re: Loss of Power in reply to souNdguy, 11-02-2006 20:41:39
OK not a problem. Oil pressure was fine. I bought new head bolt's today at the local New Holland Dealer. I should get it back together tomorrow. I'll let you know how it goes. Thank's again for your help.
souNdguy
11-02-2006 21:12:21
 Re: Loss of Power in reply to ORHotrod, 11-02-2006 21:08:24
Good luck.
Remember to retorque the head after warming the engine up some.
Soundguy
