Hey Dell, other
10-30-2006 17:47:31
Ron,ar here,again: I finally got the new autolite plugs installed today. I also installed a new, better quality plug wire set. I had already installed a new set but they were the cheapest I found. Remember, back when I first brought this tractor home it did not run and I just wanted to get it started to see what I had before I spent too much initially. Anyway, I put the new wires and new autolite plugs in. Our Napa store could only provide Autolite 216 plugs for some reason. It seems to run better and I checked the spark at dark so I could really distinguish the color. It is definatly blue and will jump about 1/2 inch gap so I am pleased with that. Now about the stumble at WOT. I have not tried it with a load so that is still a question unresolved except I am still learning a few things about the "hole" I drilled in the top half of the carb. If, after I let it warm up first, I go from idle to WOT, the hole has to be uncovered or it stumbles a lot. No amount of adjusting solves it either. Now, if I set the lever at idle, cover the hole,it runs fine, but at low idle it always did. However, with the hole covered, if I slowly move the throttle lever to WOT it does not stumble at all. It is only if I go from low idle to WOT quickly that it runs rough. I checked fuel flo again, thinking it was too little fuel flo and could not "catch up". I has plenty of flo. I rigged my timing light up on a set of temporary reference marks and it appears to be advancing tho I do not know for sure how much it should advance. More as I learn.....thanks.
