disk
North Texas 8N
11-03-2006 18:10:10
Have a set of looks to be 8 foot tamdem disk, how often should they be greesed while in use.
Jimmyjack
11-03-2006 21:03:48
 Re: disk in reply to North Texas 8N, 11-03-2006 18:10:10
On the newer discs with seals it is best to not over grease (push the seals out) and with good grease 10 hours is about right. On old ones with questionable bearings I really dont think you can over grease them.
Mike OH
11-03-2006 18:35:46
I've got a Ferguson tandem disks and was told from the old timer I got them from not to grease them because they had wooden bearings and the grease would mix with the dirt and wear the bearings out. I also have a new tandem disk and the fellow that sold them to me said to grease them every four hours. So that's what I've been doing and so far so good..... ..... ... at least I think so.
old
11-03-2006 18:16:49
Depends on how much they are used. The rule of thumb is every day or daily which ever you want to call it.
