Ferguson Plow / Plow bolts
Ken McGuire
11-04-2006 18:57:38
I'm trying to put my Ferguson 14-AO-28 plow back together. Everything's apart, blasted, primed and ready to go except for plow bolts. Probably half of the originals are still usable if necessary, but I have been unable to find correct replacements. The plow had 22 bolts 7/16-20, 1" long, and 4 bolts 7/16-20, 1-1/4" long. All the local ag and bolt stores seem to have are 7/16-14, 1-1/2" long. Sweigard has some 7/16-20 bolts, but they are 1-5/8" long and not threaded all the way up to the head. They might work for the 4 longer bolts.
Anyone know of a possible source for the correct bolts? Any opinions on using the coarse threaded bolts and nuts?
Also, would you paint the plow Ferguson Gray or 8n Gray?
lonestarjeff
11-04-2006 19:32:32
 Re: Ferguson Plow / Plow bolts in reply to Ken McGuire, 11-04-2006 18:57:38
Ken...for what it's worth I used the course-thread plow bolts(from TSC)on both of my Ferguson plows. They had the 1" & 1 1/2" bolts & they work fine. The tough ones for me to find are the BIG ones going thru the landslides.
Do you have a serial # on your plow?
I'm staying w/ Ferguson gray on mine.
Jeff
Bob
11-04-2006 22:53:41
 Re: Ferguson Plow / Plow bolts in reply to lonestarjeff, 11-04-2006 19:32:32
1.) There is only ONE "l" in LANDSIDE.
2.) I can't help with FINE thread plow bolts, but for COARSE ones, Deere has a great selection:
7/16" X 1" = Deere Part # 10H1071
7/16" X 1.25" = Deere Part # 10H1072
3.) Do you know the size and length of the LARGE ones you mentioned for the landside?
lonestarjeff
11-05-2006 07:58:11
 Re: Ferguson Plow / Plow bolts in reply to Bob, 11-04-2006 22:53:41
Bob...I must have had a brain-lapse, usually I am cracking up at other people adding the extra "L" in that word.
Also, forgot to mention those plow bolts I got at TSC came w/ a locknut.
The large plow bolt for the landside is a 5/8"-18 x 3 1/4" flat head, sq. neck.
Jeff
Bob
11-04-2006 10:04:33
 Re: Ferguson Plow / Plow bolts in reply to lonestarjeff, 11-05-2006 07:58:11
I shouln't have even commented on the "landside", it's just that knowing anything about the parts of a plow has become a "lost art"!
Once again, there's no fine thread choice, but Deere has the 5/8 X 3.25 plow bolts, part # 09H1768.
lonestarjeff
11-04-2006 10:24:25
 Re: Ferguson Plow / Plow bolts in reply to Bob, 11-04-2006 10:04:33
Thanks for the info, Bob, & I know what you mean about the "lost art".
There is a Deere dealer on the way to the farm. This is the first time I've had a reason to stop there.
Jeff
Bob
11-04-2006 12:19:40
 Re: Ferguson Plow / Plow bolts in reply to lonestarjeff, 11-04-2006 10:24:25
Whether or not anyone is a Deere fan, their parts system is second to NONE. The dealers have hardware and bearing cross-references, IF the parts guys are willing to get them out.
The jdparts.com site has a parts search by part "specs", and that's where I checked on the plow bolts.
(At the dealer I'm signed up with, the large plow bolts are $2.00 each.)
As with everything these days Deere parts often aren't cheap, and they have quite a "rep" for that. However, I did find one exception this summer.
I needed a throwout bearing for an 860, with the dual clutch. The local NH dealer priced it out @ about $97.00. (I wonder if they made a mistake?)
A local auto parts store I buy a lot of parts from came up with about $35.00.
NAPA, in another town, wanted $48.00.
Just for the heck of it, I punched the Aetna Bearing number into jdparts. Their price was about $22.00. I ordered it, and it came in an AETNA box, with a Deere part # sticker on it, same AETNA part number on the bearing, as the original. So, you never know who will have the best deal.
Ken McGuire
11-04-2006 20:01:44
Serial # 92406
