Wagner Loader hyd cyl problem?
Popster
11-06-2006 19:42:17
My Wagner load has suddendly stopped going all the way down. When I try to lower the arms, it travels to about 2" from the ground. The right cylinder seems to stop. It's almost as if there is something in the cylinder that is keeping it from retracting all the way. Any ideas.
This poor rig as seen some heavy use in moving rip rap.
Thanks.
HowieNJ
11-07-2006 15:28:08
 Re: Wagner Loader hyd cyl problem? in reply to Popster, 11-06-2006 19:42:17
if i remeber right there's a large nut on the end of cyl holding the packings of oil seals and stuff. very possible it has come off if so it's not working on it's own power but with help from the working cyl. does loader seem weak? if so take one pinn out of cyl and see if it works on its own.good luck
Popster
11-07-2006 17:17:04
 Re: Wagner Loader hyd cyl problem? in reply to HowieNJ, 11-07-2006 15:28:08
Good idea. Thanks. I give this a try and see if it identifies problem.
Popster
11-07-2006 10:00:14
Thanks for the advice. I'm located in Maryland and the problem started with temps in the 80's. No ice.
The problem also started during regular light usage- picking up a small load of 2x8 trash after Ernesto. Perhaps 15 pieces about 6' long. Not a big load.
When I lower the rig, it sounds like there is a metal object inside the right cylinder (not the bucket cylinder) that keeps the arm from going down the last few inches.
Thanks for all the suggestion so far!
Dal
RockyMO
11-07-2006 05:18:48
My first thought,since it has recently seen a lot of heavy loads is that the cylinder might be bent. Inspect the cylinder closely.
Rocky in MO
Hank ABAB
11-06-2006 21:29:35
Ice, maybe? Did water somehow get in and freeze?
Jack-Illinois
11-07-2006 06:04:56
 Re: Wagner Loader hyd cyl problem? in reply to Hank ABAB, 11-06-2006 21:29:35
Good thought, but Illinois is not quite cold enough for that solid of freezing yet. Notice I said "yet"?
Hank ABAB
11-07-2006 10:02:26
 Re: Wagner Loader hyd cyl problem? in reply to Jack-Illinois, 11-07-2006 06:04:56
Excuse my ignorance, but how can you tell that "Popster" is from Illinois? From previous posts? There must be more than one way to tell.
I tried to figure this out before I replied, as I am from a part of North America where ice is now a problem.
Anyway, the answer would be interesting to me, thanks.
Jack-Illinois
11-07-2006 17:09:06
 Re: Wagner Loader hyd cyl problem? in reply to Hank ABAB, 11-07-2006 10:02:26
Well the answer is I just plain screwed up!! I think I had read the post above this one from Rod Illinois and was still stuck on that name. Sorry about that. - Jack
HowieNJ
11-06-2006 20:05:27
dont no to much but with bucket down try bleeding the return line mybe air stopping cyl.or to much oil?
guest
11-07-2006 04:18:13
 Re: Wagner Loader hyd cyl problem? in reply to HowieNJ, 11-06-2006 20:05:27
Poopster,
Howie is right.
I would put loader in down position
and crack the hose and let a little
fluid out.
If it still doesn't go down then
Hank is right.
Use a propane torch to apply a LITTLE
heat to the cylinder to melt the ice.
