The Thrill of Victory
Rod From IL
11-06-2006 19:44:15
No Longer a no start. After a carb rebuild and putting in IE ( found the real problem ).
The Carb Rebuild was just for the heck of it but the IE was because I was fed up with the Points. As I pulled the points plate I found the waits were messed up and fixed them. I figured that they were the big part of the problem. The carb needs some help( have to pull the choke a little to run smooth) but I am getting GREAT spark now. Thanks all.
RP-40-9n
11-06-2006 20:41:24
 Re: The Thrill of Victory in reply to Rod From IL, 11-06-2006 19:44:15
rod,glad you got her goin. if you open your main throtle valve another half to full turn you wont have to choke to run good. RP
