Hydraulic lift shaft lubrication
Rich in NJ
11-09-2006 10:17:21
I am in the middle of overhauling my hydraulic system and was curious about the hydraulic lift shaft and its bushings. Since there aren't any grease fittings to lubricate/grease up the shaft-to-bushing fit, what is the best way to handle this area? Should I simply apply a layer of grease prior to putting everything back together, or should I leave everything alone and figure that some "splash" lubrication will occur from the hydraulic fluid sloshing around inside? I couldn't really find anything in the Archives that addresses this.
doncam
11-09-2006 15:18:46
 Re: Hydraulic lift shaft lubrication in reply to Rich in NJ, 11-09-2006 10:17:21
If those bushings in there are the same as on the 00 series they are oil impregnated. I did put grease on mine though.
Hobo,NC
11-09-2006 17:11:21
 Re: Hydraulic lift shaft lubrication in reply to doncam, 11-09-2006 15:18:46
Iffin you won’t to nail the timing click on Hobo’s and go to Engines or if you feel luckie line'em up and move on.
Third Party Image
OH Boy
11-09-2006 12:02:18
I applied grease all over mine when I had it apart.
