Order Ford 8N Parts Online
8n compression
Rokhd
11-12-2006 12:28:10
On a 1948 8N Ford what is the compression suppose to be, and what is acceptable?
Rokhd
11-12-2006 12:56:45
 Re: 8n compression in reply to Rokhd, 11-12-2006 12:28:10
Thank you
Dell (WA)
11-12-2006 12:48:31
Rockhead..... ...Ford specs for the flathead N-Engine is 90psi MIN (dry).
Engine in good shape about 110psi. Just rebuilt engine about 125psi. Just for grins, my 1969 BMW 2002 with 385k-miles checks about 165psi. Just for grins, my Dodge Cummins Diesel about 220psi.
HTH..... ...Dell
Bruce (VA)
11-12-2006 12:35:04
90 lbs is about the minimum you want to see, w/ the lowest reading w/in 75% of the highest. 120 after a rebuild is about as good as it gets. Anything below 90 & they get hard to start. Check out tip # 46 to make a compression check easier.
http://www.ytmag.com/articles/artint268.htm
