Order Ford 8N Parts Online
Draft control on 8N
rainyweekend
11-12-2006 15:06:03
I could use some advise on the draft control on my 1948- 8-N . With the lever all the way up it does not work, with it 1/3 down it seems to work fine, and with it all the way down and me pushing hard on it works, but as soon as take my hand off the plow drops. I assume I have a worn part, or it needs an adjustment. Also their is a large screw maybe 5/8 just above the level, but it seems frozen. Any suggestions?
Thanks Ron
Dunk
11-12-2006 16:14:04
 Re: Draft control on 8N in reply to rainyweekend, 11-12-2006 15:06:03
I just posted in the last few days the manual on this.
Something I did postint it caused it to be frigged up.
I couldn't even post a reply to it.
I use some http code to post some of the things I post here..
I may have screwed something up[ in the topic.
Anyhow here is the link
rainyweekend
11-13-2006 04:35:10
 Re: Draft control on 8N in reply to Dunk, 11-12-2006 16:14:04
Thanks i'll read through it and see if i can figure it out
rainyweekend
11-13-2006 05:51:36
 Re: Draft control on 8N in reply to rainyweekend, 11-13-2006 04:35:10
Well i read it! Scared the hell out of me!. Can you tell me what that large screw bolt is ? Is it a adjustment for that draft lever?
