Dell(WA) compression testing
RickSCt
11-12-2006 16:24:23
Dell I have a question about testing compression on a 9n. I did a compression test in the spring on my tractor but I did it when the engine was cold. Would the results be much different on a hot engine? Thanks Rick
Dell (WA)
11-12-2006 16:53:21
 Re: Dell(WA) compression testing in reply to RickSCt, 11-12-2006 16:24:23
Rick..... ..iff'n yer testing for "money", a WARM engine is slightly more "accurate". But iff'n yer engine is really bad or has a stuck ring, burned exhaust valve, or blown headgasket, a general compression test (cold) is usually more than adequate to confirm yer suspicions..... ...Dell
