New toy
RockyMO
11-14-2006 13:53:55
third party image
I picked up a new toy over the weekend, a Ferguson T0 30. Looks pretty good,runs good, one new rear tire, one good rear tire, new front tires, good hydraulics, recent governor o/haul and even has working brakes. Anyone have info on these? serial number location and description etc.. I thought the price was pretty fair, $1500. I went to town to get ziplock bags and came home with a tractor. Sometimes I just don't understand why my wife is always mad at me.
Rocky in MO
Colin King
11-15-2006 09:22:54
 Re: New toy in reply to RockyMO, 11-14-2006 13:53:55
That"s a great looking TO 30! Have fun.
Colin, MN
LeeMo
11-15-2006 07:27:21
Looks good, Rocky !! I was looking at one of those a couple of weeks ago. If I'd had the chance to buy it for what you paid it'd be at home now too. Sounds like a good deal !!
FarmerDawn
11-14-2006 15:49:44
WOW! When *I* go to town for plastic bags, I just wander around until I give up trying to remember what I went to town for. LOL
That's just a beautiful machine! No wonder you snapped it up! Congratulations!!! --Dawn
Ross Pugh(NC)
11-14-2006 14:50:29
Rocky, I know what ye mean, that sounds like some of the things I do. I don't worry about it, she always gets over it.
Jim.UT
11-14-2006 14:21:35
Here's your photo:
third party image
And here's my TO-30 that I acquired last month when my uncle died. It was running when he started having health problems several years ago. It hasn't been run since and now the engine is locked up. I'm still soaking the cylinders in ATF, but pretty soon I'm going to give up on that idea and pull the head.
third party image
third party image
The serial number is on a tag on the dash, above the steering column. The tag should have a "TO" printed on it followed by a stamped s/n. Mine is a 1952, s/n 80236 (if I remember right).
Paul in MN
11-14-2006 19:59:51
 Re: New toy in reply to Jim.UT, 11-14-2006 14:21:35
Jim,
Nice looking TO 30, but be careful with the amount of force you create in breaking the engine loose. It is a Z-129 Continental overhead valve engine. It is a wet sleeve engine meaning thast there is no block casting along the sides of the cylinder bores. The sleeves are set in a rubber o-ring at the bottom of the water jacket area and are held in place at the top by the head sandwiching them into the block casting. If you move the sleeve with the head off, you will leak antifreeze into the oil pan and may not be able to get it to seal again. I would try to free it up with the head on it to keep the sleeves from moving.
Good Luck!
Paul in MN
Jim.UT
11-14-2006 20:13:29
 Re: New toy in reply to Paul in MN, 11-14-2006 19:59:51
Thanks Paul. I did not know that about the Z-129 engine. Do you have any tips or tricks for freeing the engine up with the head on? I've been trying the ATF for several weeks. Maybe the next move is to remove the starter and pry on the flywheel with a prybar?
Dan S (NY)
11-15-2006 09:35:49
 Re: New toy in reply to Jim.UT, 11-14-2006 20:13:29
third party image
Don't worry to much about the sleeves if you end up pulling the head. If a sleeve moves, you can just pull it all the way out, clean things up, replace the O-rings and reinstall it. Use some Vaseline on the O-Rings to help them slide back in. You should drain the antifreeze from the engine before you do any of this of course... Here is a picture of the engine with all the sleeves removed. Makes it easy to get a clean water jacket! Have fun with your TO30.
Dan
Tatanka
11-14-2006 14:02:06
You should have bought the ziplocs, that way you have someting to put the bolts in whenyou tear her down. Either way you came out ahead.
