Many thanks!
popbreed
11-16-2006 15:37:13
This forum help get me through my first rebuild of a tractor. I started the motor last night and she runs great. It is still on jack stands, red paint done, rewired, new brakes, new seals. Just need to finish the sheet metal and wheels.
Had an oil leak but just the oil line from the filter to the governor. Tightened one end but forgot to go back and tightened the first end. Little bit of water at the head but the retorque appears to have fixed that. Still need to adjust the carb and governor linkage. Carb came in easy after the rebuild. Idles at 400 rpm and oil pressure is at 40 psi at idle and 60 psi at 1200 rpm.
I am happy! Thanks to all who supplied the knowledge!
Pop
FarmerDawn
11-17-2006 16:28:42
 Re: Many thanks! in reply to popbreed, 11-16-2006 15:37:13
Fantastic!! I would love to see some pictures, too! Congratulations on getting the engine running again like that. It must feel SO good! --Dawn :-)
Sean (TX)
11-16-2006 16:37:41
Sounds like is coming along good... Lets see some pics when you get her finished.
