Roto-tiller
pat
05-24-2001 18:06:10
folks have told me my 9-n is to fast for a roto-tiller.Are their any roto-tiller type attachments that are compatible with a standard 9-n drive train.
thanks
slag
05-25-2001 08:11:45
 Re: roto-tiller in reply to pat, 05-24-2001 18:06:10
Will gladly trade my old roto tiller for your old 8-n think about it.:<}
bj/8N/mt
05-25-2001 07:05:21
You would need more than just a three point attachment to do tiller work with an N since first gear is too fast for what you would want a tiller for.
Unless you have acres to till--in which case you want to look at plows and discs--your best bet is to make friends at the rental shop and get their rear tine walk behind machine.
Your mileage may vary
yep . . . Dell (WA)
05-24-2001 18:20:51
Pat..... ..folks are correct. You might want to do a search on the "archives" at the top of this great N-Board.
The N-Tractor is just too high geared to be a rototiller machine, but it is a very good 2-bottom plowing fool. And Sherman aux trannys don't help slow it down eather.
There is a rare and fragile "Howard" aux tranny that mounts behind the main tranny that does slow down the N-Tractor enuff to make it rototillerable. But most Howards have been "trashed" because they really wern't strong enuff.
Now then, that hydraulic 3-point lift is a really neat scheme and I have seen 6' rototillers with an auxillary 10-20 hp engine being pulled thru the soil behind N-Tractors and at the end of the row the tractor lifts the rototiller up and then turns around and goes the other direction.
At the time I saw these aux engine rototillers, I really didn't pay attention to who made them and I haven't seen any since 1975..... ...Dell
Mountainman
05-25-2001 00:25:34
 Re: Re: roto-tiller in reply to yep . . . Dell (WA), 05-24-2001 18:20:51
Northern tool has something similar to the aux engine tiller you mentioned but it is not three point equipment.
fwiw
Mountainman (CA)
