12V Headlights
Nova
05-24-2001 18:09:12
I have just installed a 12volt conversion, Now I need to replace all the lights to 12v. Can I just replace the bulbs or do I have to replace the complete units?
Mike S
05-25-2001 03:45:53
 Re: 12V Headlights in reply to Nova, 05-24-2001 18:09:12
You can keep the six volt lamps if you wire them in series. That way it will take the 12 volts to make them light up and they won't burn out. I think someone did a drawing and it might be in the archives.
yep, just like Chrismas Tree lights . . . Dell (WA)
05-25-2001 08:12:34
 Re: Re: 12V Headlights in reply to Mike S, 05-25-2001 03:45:53
If'n ya went to the 'spense of converting to 12 volts, do the job right an' use real 12 volt lights..... Dell
Robert 8N431445robert1409@prodigy.net
05-24-2001 18:32:05
You only need to change bulbs or sealed beams, which ever your tractor has. Mine has only sealed units
