Order Ford 9N Parts Online
stud removal on a 9n, need some advice
antster
11-20-2006 19:11:16
Hello, just ran into a little problem on my 9n engine. I took off the head and now there are a few studs that didn;t come out. And they are in there pretty good. What should I do. I know if I try to hard they will break right at the deck of the motor. And I sure don"t want that. I think I"ve heard of a stud removal tool. But do they work on these old motors. This is something I though of, but I haven"t did it yet. So that is why I"m writing to who ever is reading this and has came upon this problem. If I was to slowing warm up the engine block with a torch, especially around the deck of the block, if I was able to get heat in the area where the stud are. That this might make studs come out a little easier. Just something I thought of, Please your in put would be great. Thanks for taking the time to read this..... Anthony
ZANE
11-21-2006 07:23:35
 Re: stud removal on a 9n, need some advice in reply to antster, 11-20-2006 19:11:16
The only negative I see with studs in the block is it's harder to remove the head and harder to clean the deck of the block of the old gasket material. Other than that and maybe a bad thread on the stud I think studs are a lot better than bolts. Bolts will if used enought times ruin the threads in the block. Bolts can not hold the head on as tightly as the studs can because the stud nuts are fine thread and fine threads will hold nearly twice the downward pressure as a standard course thread simply because of the mechanical advantage of the lesser incline of the threads.
Bolts came into favor not because they are better but because they were easier to assemble.
Zane
TheOldHokie
11-21-2006 10:33:20
 Re: stud removal on a 9n, need some advice in reply to ZANE, 11-21-2006 07:23:35
The studs are UNF on one end and UNC on the other. Both head bolts and studs hold the full tension of the connection so you don't gain anything in that regard with studs. Weakest link is still the UNC thread which is the same for bolts and studs.
YMMV,
TOH
ZANE
11-21-2006 14:43:16
 Re: stud removal on a 9n, need some advice in reply to TheOldHokie, 11-21-2006 10:33:20
If both the bolt and the fine threaded nut on a stud are torqued to the same value the stud and nut will exert almost twice the down pressure on the head.
This is an engineering fact.
Zane
TheOldHokie
11-21-2006 16:16:43
 Re: stud removal on a 9n, need some advice in reply to ZANE, 11-21-2006 14:43:16
"If both the bolt and the fine threaded nut on a stud are torqued to the same value the stud and nut will exert almost twice the down pressure on the head".
Sort of. I don't know about twice the force on that particular diameter and pitchs but yes the nut will produce more tension in the fastener at the same torque. However that misses the original assertion that the strength of the connection is stronger - it is not. The weakest point in the system is still the threads in the block where the stud engages. The block end threads on the stud will fail at exactly the same tension as they will with the bolt (assuming like materials). That too is an engineering fact.
The relationship of torque, thread pitch and tension is why the recommended torque values for the bolts are HIGHER. The higher torque results in the SAME tension in the bolt as you get at the lesser number for the stud. Two different torque values but the same clamping force and the same load on the threads in the block.
The strength of a threaded connection is simply a factor of how much cross sectional area is engaged by the threads and the tensile strength of the material. Because the Unified thread profile is 60 degrees and the root depth of the thread diminishes with finer pitches you get less area engaged per thread with fine threads but more threads engageed for the same length of engagement. The percentage by which the area dimenishes is less than the percentage by which the number of threads engaged increases - hence finer threads for any given diameter have a greater cross sectional area engaged and are stronger.
A simple synopsis of the engineering formulae involved may be found in Machinery's Handbook. A full and definitive analysis may be found in Federal Standard H28, first published by NBS shortly after WWII and revised a few times since to accomodate more recent thread forms. Frankly i prefer the Machinery's Handbook. My eyes glazed over within 5 minutes of opening H28.
Regards,
TOH
don b
11-22-2006 11:51:44
 Re: stud removal on a 9n, need some advice in reply to TheOldHokie, 11-21-2006 16:16:43
Hokie.....not to get into the other posts because I don't know.I have a question tho....When torqueing a BOLT....is that not just stretching the threads to bind the two parts together?On a STUD...when torqueing,are you stretching the threads on BOTH ends of the stud or just the end where the nut engages the stud?This NUT would like to know.Thanks, don b
DonCam
11-20-2006 22:51:57
I agree with Paul in MN's method, it's the best method I have seen work. Quit a few folks use it including myself and it works great. I usually cool the stud with water immediatly though, it seems to work too. I have used the oil too.
Dunk
11-21-2006 03:09:47
 Re: stud removal on a 9n, need some advice in reply to DonCam, 11-20-2006 22:51:57
Water?!?!
On hot cast iron block?!?!
I wouldn't try that one on my block.
135 Fan
11-20-2006 21:35:25
Welding a nut on the stud or a piece of flat bar with a hole in it usually works very well. The instant heat from welding expands the stud and as it cools of it shrinks and comes loose. Let it cool a bit so you don't twist it off when it's red hot. Hope this helps. Dave
Peter, Covington, LA
11-20-2006 20:12:32
If you decide to use the old reliable penetrating oil method, and you take the time to read the instructions, you will note that all penetrating oils (at least ones I have ever seen) say you should tap on the stud. The reasoning is that the oil seems to penetrate more readily when the vibrations from tapping on the bolt or stud are present.
The only time I had a stud like that to remove, I tried until I almost broke it, then I used penetrating oil. Following the instructions, I'd squirt a little oil around the base of the stud, then take a hammer (not a big one) and start tapping on the head of the stud. Something like 20 taps, then stop and put some more oil. Tap, oil. Tap, oil. After about 10 cycles, I was able to unscrew the stud with relative ease. I used vise-grips, and worked it back and forth a few times, then out she came.
I've seen the method described below, where a nut was welded to the end of a broken stud, touted several times on the Model T website. Apparently the heat from the welding does a similar job to the oil-tap method.
Dan
11-20-2006 21:20:36
 Re: stud removal on a 9n, need some advice in reply to Peter, Covington, LA, 11-20-2006 20:12:32
You are very correct about the way to use penetrating oil on stuck studs, except in this case. The problem with using penetrating oil on head studs is - it won't penetrate! You purposely coat the threads of the head studs with sealant specifically designed to seal the threads. Penetrating oil will just float at the surface of the block - no matter how long you tap on those studs.
Just my $.02
Dan
Dan
11-20-2006 20:08:04
Heating the block would have no affect - it is too big. If you have to remove the stud, get a stud remover and get it out. I have used a stud remover on MANY stuck studs, and none have broken yet (knock on wood).
The right tool for the job makes a huge difference.
Dan
Paul in MN
11-20-2006 19:38:59
Antster,
You are right to be leary about breaking off the studs. Most of them are into the water jacket area, so they have water or antifreeze coming up into the threads causing corrosion and weakening of the stud.
My approach would be to direct the torch flame on the stud, but not on the block. I know that this seems to be counter intuitive, as the stud expands and gets tighter in the block...but begins to break loose the corrosion bond. Then let it cool and shoot your favorite penetrating oil on it while cooling. The pen oil should work its way into the thread. Heat and cool a few more times for good luck. You are doing 3 things all at once...1) driving the pen oil deeper each time, 2) breaking more of the corrosion bond with each heat/cool cycle, and 3) each time the stud goes from red hot to cold it shrinks to a bit smaller size than it started as. Then I usually double nut it, locking the 2 nuts tight together, and then putting some forward and back wrench motion on the nuts to loosen the stud. If you have any sense that you are about to break the stud, just go back to the heat/cool & oil routine for a few more cycles. Once you get it to move, do not unscrew it in a continuous manner as it usually gets tight again, but rather unscrew it a bit, and reverse to tighten it a bit, and then unscrew it a bit further with more pen oil. Your time and patience will be rewarded by not having to drill out a broken stud.
Best of luck!!
Paul in MN
K.LaRue-VA
11-20-2006 19:36:37
First, a dumb question. Why remove them? Unless the threads at the top are bad or they have rusted badly, they can probably just stay in there and be re-used. You can check the flatness of the deck surface with a straightedge without removing the studs. Removing them without reason just adds more unnecessary wear and tear on the threads in the block.
If you have to remove them, the stud removers I have seen provide a way to clamp on and make it easier to unscrew them without getting off-center and snapping them. Should work on any engine but that is one of the few tools I have not needed to get. If you do remove them, replace with new studs and make sure you get the correct length in each hole for the head you are using.
The last really rotten set I had to remove came out with a pair of vise grips and a couple whacks with a hammer. Except for one, of course. That snapped off about a quarter inch above the head. I slipped a slightly oversize nut on what was left, covered the area with some thin sheetmetal for protection, and welded the nut to the broken stud. Then, it came right out with my impact wrench. Heat from the welding probably helped alot. Be careful with heat around the deck surface cause you might warp something.
Russ SoCal
11-20-2006 20:19:24
 Re: stud removal on a 9n, need some advice in reply to K.LaRue-VA, 11-20-2006 19:36:37
KLR,
Not a dumb question at all. The dumb part is trying to remove them when not necessary.
Harbor Freight makes a tool that looks like a deep socket with a bunch of small diameter pins in it. Sears makes one with 3 knurled wheels.
I give Harbor Freight"s almost 90%. That"s 2 breoken studs out of 18. Then 2 weeks and a bunch of money for left hand twist drill bits.
There are reasons they need to be removed. The sad thing is, mine didn"t. I figured if there was a change from studs to bolts, bolts must be better. WRONG1
Russ
K.LaRue-VA
11-21-2006 06:53:45
 Re: stud removal on a 9n, need some advice in reply to Russ SoCal, 11-20-2006 20:19:24
Right, studs reduce the amount of wear and tear on the castings especially for engines like these that were intended to be rebuilt over and over again. Most times you should be able to just run a thread chaser on the end to clean up the threads so you get an accurate torque with your torque wrench.
A few studs usually come out when you try to remove the nut. They should be replaced with new ones (but I have been known to reuse them if they look ok). At least that eliminates the usual snafu of getting the wrong length studs. Remember to put some sealant on them to seal the water jacket.
The most important things to do to prevent problems with the head is to make sure both the block and head are flat, use a good quality head gasket, follow the correct pattern when you tighten the bolts, don't overtorque them, DO go back and retorque them after the engine has gone through a heat cycle. People who have had problems will eventually admit to skipping one of these steps.
Dunk
11-20-2006 19:16:33
Well, wait on the others to post, and don"t go on what I would do, but I will tell you exactly what I would do.
I would take the torch and turn the studs red, while tryin not to heat the block anymore than I could help, then get a holt on it with vice grips and work it, and remove it.
