Order Ford 8N Parts Online
Log splitter on a 8N
Paul Smith
11-21-2006 12:30:39
Will the hydraulics on a 51 8N run a #3 JD log splitter and where would the pressure and return line connect to the tractor?
Josh0103
11-24-2006 10:53:50
 Re: Log splitter on a 8N in reply to Paul Smith, 11-21-2006 12:30:39
hello,
I have used a log splitter on my T020 for about 2 years now. It is ran off the belly pump,and Yes, it is slow,but ive got time. The connections are simple. Pressure line comes from test port,return line is connected to differential drain plug hole.Hence no drilling or tapping required.
I use quick disconnects to connect the supply and return lines between the splitter and the tractor.
guest
11-22-2006 04:08:24
You would need a Printz PTO
pump ($350)
a large resivoir and plumbing ($300)
A lot of gas / wear on your N
Why not just get a gas powered
splitter?
TheOldHokie
11-21-2006 16:47:49
Well you've been given the basics by the previous posters. At a scant 3 GPM it will be a real PITA but it will split. I have run mine off my Kubota at about 3.5 GPM and it's probably faster than a sledge (and a lot less effort) ;-)
WRT the test port that's a 1/2-20 UNF thread. A standard SAE #5 O-ring Boss (ORB) adapter will allow you to make the connection:
third party image
third party image
That's an odd size and bit hard to find. I can get them locally if you need assistance. Last one was about $12 IIRC. The return line can simply be stuck in the transmission fill hole or plumbed into a side inspection plate.
HTH,
TOH
George HArris
11-22-2006 08:57:34
 Re: Log splitter on a 8N in reply to TheOldHokie, 11-21-2006 16:47:49
I have a fitting already plumbed into the location shown in the pic. It's capped off - I was wondering what it was there for. So, does that port supply a constant hydraulic pressure when the PTO is running?
Thanks,
George
Paul Smith
11-22-2006 08:22:09
Thanks again for the replies. I sold my gas powered splitter 10 years ago when I quit burning wood for heat. I probably split less tha 2 face cord a year and I"m getting tired of the sledge hammer and wedges. I will keep my eyes open for another pump to run off the PTO. For now I just want to be able to move the ram. This sounds like it will work.
duey
11-21-2006 13:00:37
Paul, while the pressure of hydraulic system might be enough, the volume is low.... not very practical.. equals SLOW ram speed. Further, you'd need tie the lift arms down or they would just rise up and that would be the end of the 'push'.
Most often, the folks on this board recommend a self-powered splitter.... hitch it behind your trailer and bring the split wood and splitter home with you. duey
Paul Smith
11-21-2006 14:30:28
 Re: Log splitter on a 8N in reply to duey, 11-21-2006 13:00:37
I have a three point splitter already. If I wanted to try it, I still need to know where to connect the lines.
maplehillfrm,pat
11-21-2006 15:04:44
 Re: Log splitter on a 8N in reply to Paul Smith, 11-21-2006 14:30:28
I think you wont be happy with the set up either, but I believe you use the test port on the right side of the tractor coming out of the bottom of the hydro pump assy,, I also think teh threads are a different pitch if I recall from posts some time ago,, but its a start,,
when this doesnt work you can always get a pump from a dump truck and hook a pto shaft to it and run it off the tractor ,,, there are options to still allow you to use your N for splittin wood, pat
Dunk
11-21-2006 14:58:41
Paul, would you believe there is no where to connect the lines, short of drilling and tapping?
You might find a pump that will work on your PTO.
You might find a pump and mounts that will mount on the front and connect through the crank hole to the front pully on the engine.
That's about all there is within reason.
