Order Ford 8N Parts Online
8N ignition switch
popbreed
11-24-2006 14:21:51
My tractor came with a aftermarket automotive ignition switch. I replaced it with a switch that is suppose to be a 8N replacement. When it is mounted, the "ON" position (key cannot be rremoved)is vertical and the "OFF" position (key can be removed)is horizontal. Is that correct? It seems odd to me but since the switch hole has the flat and the switch has a corresponding flatr, there is no adjustment that I can see. Thanks for the help.
POP
popbreed
11-25-2006 14:20:14
 Re: 8N ignition switch in reply to popbreed, 11-24-2006 14:21:51
Sounds like a mixed bag. Thanks for all of your input. Guess I will just leave it as is.
POP
old
11-24-2006 16:41:59
All my Ns have it so when on its up and down and off its laying flat all of them have always been that way. My 841 is also that way
Dunk
11-24-2006 16:08:44
I have a high capacity toggle switch, of course my N stays in a steel building "shop", that is guarded by 15 dogs and a shotgun...
Empennage
11-24-2006 15:34:22
You can always loosen the locking nut and spin the lug.
Drmeatman
11-24-2006 14:38:54
Popbreed, my switch(and others I have in a "spare" box)all are in the on position switched to the right and horizontle.
Bruce (VA)
11-24-2006 14:35:54
Beats me..... .my 50 frontmount w/ what looks to have the OEM switch is like that. The other two, w/ aftermarket replacements 'like the OEM switch' are just the opposite.
