Using 3pt to pull T posts
Pooh Bear
11-24-2006 18:41:40
I have some very stubborn T posts I need to pull up.
If I back up to them with the 8N,
could I use the 3 point hitch to pull them up.
Can I just chain to the post and one of the lift arms?
I tried one of those Hi-Lift farm jacks, the 48 inch model.
I would jack it up and the post would just lean over.
And it was real hard to jack up. This jack is
supposed to have a 7000 pound capacity. Maybe
if it had a 10 foot cheater bar. But it was all
I could do to jack it up with the post chained to it.
So I'm wondering if the 3 point hitch will be
strong enough to pull a T post.
I don't want to have to buy a T post puller just
for the few T posts I need to pull up.
Anyone got any better ideas?
Thanks.
Pooh Bear
AM-Seb
11-25-2006 23:45:21
 Re: Using 3pt to pull T posts in reply to Pooh Bear, 11-24-2006 18:41:40
I use my 3pt lift carrier (kind that has 2 arms extending back, not pole lift type). I back squarely to the T-post with lift arms very low then wrap a piece of chain tightly several times around it and fasten links through 2 bolts and nuts to the center of the lower crossmember on the lift. Posts lift out easily enough in our clayey soil. I have 90# each front wheel weights and never any front end lifting. Even so, I wouldn't try it on a hill where front wheels are higher than the rear wheels.
Pooh Bear
11-25-2006 17:51:07
Well, today I managed to get the stubborn T posts out.
I already had the rear dirt scoop on the back.
So I just backed up to each T post and chained to it.
Hooked the other end to the dirt scoop and lifted.
First post I had to work the lift up and down.
The second post the hydraulics weren't strong enough.
I could hear that screeching noise that tells me
when the relief valve blew out. So I raised it as
high as it would go then hopped on the tractor
and drove it forward. The front wheels came off
the ground so I hit the clutch. Then I did this
a few more times and finally the post came out.
It bent the post but it did come out. And it had
a whole bunch of old barb wire hooked to it so I
just kept going till all that was pulled out of the weeds.
I don't have an 11 hole drawbar thingy.
Can't think of any reason to buy one.
Thanks for the help. I got-r-done.
Pooh Bear
B. Jones
11-25-2006 10:48:54
For many years we have used a chain and the 11 hole drawbar just like some of the other posters. Unless you were lifting and trying to pull forward at the same time the front end never comes off the ground. Some times I would use the clutch to ROCK the tractor back and forth to help loosen the post. This seemed to work real well for us. Even when I was 9 years old I ran the tractor and dad would do the chain work. B. Jones
HA POOH!!
11-25-2006 08:34:34
Don't pullum from a drawbar!!!! MUCH safer to pullum from a 3 pt. impliment cause that top link is made to keep the tractor from flippin. Be safe.
Boss Hog
11-25-2006 06:40:51
The method I use takes 2 people, but is very fast.
I put a cross bar in the lower arms of the 3 point hitch. Then I hook a log chain to it, with about 8' or so hanging off the back.
The guy on the tractor backs up to the post, so the cross bar is almost against the post. Then he lowers the arms all the way down.
The other person throws 2 loops of the chain around the post, and pulls on the other end just enough to keep some tension on it.
The tractor driver then lifts up the 3 point arms and the post comes right out. All you have to do is untangle the post and move on to the next one.
It works slicker 'n snot on a brass doorknob.
Nilram MN
11-24-2006 21:13:56
The easiest way to pull a post is to wrap a chain around the bottom of the post and over the top of a length of 4 ft 2x4 or 6. Position the 2x next to the post. Hook the other end of the chain to the hitch and drive away. With this method the 2x acts as a piviting point and lifts the post almost straight up and out with little effort needed by the N.
JR in Indiana
11-24-2006 19:36:19
I've pulled a bunch of T-posts by wrapping a chain around the drawbar and around the T-post.
I start with the drawbar in the lowest possible position, and by the time I get it raised to the highest position, I can usually pull it out by hand.
If not, lower the drawbar and hook the chain around again.
Raise the drawbar slowly and they'll come out easily.
old
11-24-2006 18:56:01
Can be done with a 3 point but be careful when doing os or you could flip the tractor over on your self. I would use a 3 point draw bar and keep you foot on the clutch pedel and one hand on the 3 point control. My self I use my loader if I have to pull posts out that way I know it will not end up on my head.
Dunk
11-24-2006 18:46:17
I do that all the time!!
I have a chain on my all purpose plow, and my scrape blade, and that is the reason!!!
Pooh Bear
11-24-2006 19:12:53
 Re: Using 3pt to pull T posts in reply to Dunk , 11-24-2006 18:46:17
But if I have an implement on the back
it has to lift the weight of the implement too.
Otherwise I would just back up to it with my dirt
scoop and chain to that. I mite try that.
Good point about flipping over backwards.
My lift doesn't come up that fast.
I think I would notice the problem before
things got too out of hand.
Thanks.
Pooh Bear
Jim.UT
11-24-2006 22:16:45
 Re: Using 3pt to pull T posts in reply to Pooh Bear, 11-24-2006 19:12:53
I've used the three point hitch to pull posts. I use an 11 hole drawbar between the lift arms and chain the post to that.
Also, I stand next to the tractor while doing it so I can kind of see both the progress of the post pulling while also seeing if the front of the tractor is starting to come up.
