Order Ford 8N Parts Online
8n air filter
1951G
11-28-2006 11:11:19
I'm posting this message for a friend of mine that's trying to restore a 52 Ford 8n. He's got the air cleaner wire with the mesh inside of it out and it's pretty much falling apart. Does anyone sell these or is there something else he can replace the mesh with? I was thinking maybe steel wool that was torn apart and packed inside of the wire cage, but I didn't know if that would be too much to restrict air flow.
Dell (WA)
11-28-2006 12:17:52
 Re: 8n air filter in reply to 1951G, 11-28-2006 11:11:19
third party image
1951G..... ..would you believe our host Yesterdays Tractors online store sells replacement airfilter screen? $10 (cheap)..... ..Dell
Allthumbs
11-28-2006 11:33:40
The cap on my crankcase breather was missing the wire mesh. I bought kitchen copper scouring pads and unraveled the pad and managed to thread enough through the small holes at its base. These pads are availble in stainless also. May be worth a try if you can't find a regular filter. Regards
souNdguy
11-28-2006 11:31:29
NO STEEL WOOL.
Either get the right stuff from the link.. or use stainless steel pot scrubbies.. 3/1$ from the dollar store..
Soundguy
K.LaRue-VA
11-28-2006 20:29:07
 Re: 8n air filter in reply to souNdguy, 11-28-2006 11:31:29
Wow! No Kidding!
Imagine what all those loose metal fibers would do when they get sucked into the engine and then partially melted, burned, etc as they go through everything. Be better off to run with nothing in there than to use steel wool for a temporary fix.
Ten bucks for the right part vs a $1200 rebuild.
souNdguy
11-29-2006 05:09:12
 Re: 8n air filter in reply to K.LaRue-VA, 11-28-2006 20:29:07
Carb 'd be useless afterwards too.
Soundguy
Ross Pugh(NC)
11-29-2006 16:23:02
 Re: 8n air filter in reply to souNdguy, 11-29-2006 05:09:12
Yes , and people who don't think steel will burn, just take a piece of plain steel wool and put a match under it and see how long ye can hold it>>SURPRISE-SURPRISE! !
1951g
11-28-2006 11:31:26
 Re: 8n air filter in reply to Hank ABAB, 11-28-2006 11:13:23
Thanks for the info.
