coil question
ron,ar
11-29-2006 21:14:06
I still have not found a good part number for a 12V coil for Oriellys but I did see OLD's reply. Now, the question...
Did misunderstand the reply; "The part number is Borg/Warner E-58. Its a 6 volt coil not a 12 volt one so a ballast resister is needed". Are you saying that if I have converted to 12 volts and have a good 6V coil I can add the resistor, cutting down the voltage to the coil down to 6V I can run the 6V coil and be ok? I have the coil I replaced when I converted to a 12 volt system and I am sure it is ok, but it is not marked, so I assumed it was 6 volt as the tractor still had a 6v generator and original wiring harness. Thanks for any help, we may have bad weather tomorrow night and I would like to resolve this quickly.
old
11-30-2006 13:15:01
 Re: coil question in reply to ron,ar, 11-29-2006 21:14:06
I double checked today and all O'reillys lists is the 6 volt coil B/W E-58 but the nice thing is the life time warrenty they have so if you burn it up they will replace it for free but the cost up front hurts at around $65 and the is for the front mount
Jerry/MT
11-30-2006 13:00:53
NAPA has a real 12 V coil (IC-14SB) for about $15.No ballast resitor needed as it's built in.
GB in MT
11-30-2006 02:26:31
ORRRR!!! you can go right to parts on this web and buy youself a brand new 12v coil for $32.59. CK. IT Out. GB
ron,ar
11-30-2006 05:07:08
 Re: coil question in reply to GB in MT, 11-30-2006 02:26:31
I also am aware of that fact, I looked there first. Also have a new Dennis Carpenter catalog but.....time is of the essence here, I need this thing running today if possible...why didn"t I just remember to turn the key off:^)
(Thanks for the reply with the good advice tho, we do owe it to the creators and keepers of this good site to try and purchase some stuff here too)
Ron,ar
GB in MT.
11-30-2006 05:15:38
 Re: coil question in reply to ron,ar, 11-30-2006 05:07:08
Ron: I had that same problem once. I keep my 2N in the work shop, so I took the key to the shop and put it on the tractor key ring, walla, if I forget when I leave the shop, I go back to get the key out of the ign. No more leaving the key on the 2N. LOL GB
Bob
11-29-2006 21:44:51
Front-mount distributor, right?
The 6-Volt coil can be used on 12-Volts by adding a "converting resistor" of 1.6 to 1.8 Ohms in series with the OEM ballast resistor.
ron,ar
11-29-2006 21:54:14
 Re: coil question in reply to Bob, 11-29-2006 21:44:51
Thanks Bob.
