coil testing
Ron,ar
12-02-2006 15:59:15
third party image
I asked last week about using a 6V coil on my 12 volt system after I had left the key on and had a no start condition due to no spark, not dead battery. I installed my old original ballast resister, the 6V coil and a ceramic resistor from NAPA that was supposed to be 1.8 ohms but actually tested out at 2.1 ohms. (Napa's book listed as 1.83 ohms) It would not start, no spark. I had voltage at the top of the dist and it pulsed with the rotation of the engine showing me the points were opening and closing.
I had another resistor of unknown resistance (left ohmmeter at work) which I tried, still no start, no spark. I removed the dist, checked the points and condenser using jumper wires, an old automotive round coil and homemade sparktester/sparkplug. It showed spark ok. I then backed up, went around the ballast resistor, using just the unknown ceramic resistor. Spark yes, engine starts yes, Questions answered no. I know the unknown resistor will remain a mystery in the equation until I ohm it but I question why the 1.83 Napa resistor and ballast resistor would not work? I also tried it straight across using just battery voltage without results. I read a lot on here about testing coils and understand how to read the ohms across a coil and that it may be good cold but not after warmup. I am more interested in building a setup that I can test a bench coil using jumper wires, points/condenser or maybe an old auto distributer. At my dad's old shop is an old dist tester called a stroboscope, I may get it and see if it can be of any use to me.
MikeT
12-02-2006 22:02:47
 Re: coil testing in reply to Ron,ar, 12-02-2006 15:59:15
Ron - If you have the equipment to measure 2.1 ohm, then surly you have an older style ampmeter. Put it in the primary circuit of the coil (in series) and measure the amps. Should be 3 - 3.5 amps for a 6 volt coil and 4 amps for a 12V coil with the points closed or shorted out.
Jim West TN
12-02-2006 18:33:35
The ballast resistor is open/faulty/bad.
Jim
Jerry/MT
12-02-2006 18:25:03
I'd sure like to hep you solve this puzzle but I'm having a hard time following all your permutations. Can you just draw a circuit diagram of what didn't work and what did? I can't tell whether you have a bad coil or a bad resistor because I can't figure out what your primary circuit looked like as you changed configuration.
Jerry/MT
12-02-2006 17:57:17
