There is no position control on a 9N/2N hydraulic system, to get that you have to add a Zane Thang ($80 and well worth it). The draft control plunger and spring are pretty integral parts to the whole hydraulic control linkage so if they have gotten broken I can see how it could really affect your control of the hydraulic lift. The control valve does not have to move in and out of its valve body very much to function, so if anything is bent in the linkage, that can easily cause it to not work properly. The top cover does lift right off but you have to disconnect the linkage from the control valve first, you can do this by reaching in through the inspection ports on the sides of the housing. I dont recall that cover being more than about 75 pounds when I had mine off, it was heavy but not so much that I could not manhandle it on and off by myself. Re your question about why the mower stayed down I think this perhaps is just a coincidence, the control valve just happened to be in 'down' position at the time. Open the tractor up and take inventory of the parts that are broken bent or otherwise damaged. The system is not complicated, you will be pretty amazed at how simple it really is when you get it opened up. This is not a 'major' thing to fix. While you are in there you might think about replacing your lift piston and rings too, if it needs that.
