JOE, I have owned several "N"-series tractors over the years, and have never had a head gasket failure. Yet, almost daily, someone posts on this board about head gasket failures, often MULTIPLE head gasket failures. So, this all DOES matter. IMHO, if the head and block are clean and "true", and a good gasket is used, along with good original-style fasteners, and proper torque, there should never be a head gasket failure. What Dan is doing is going BEYOND this, with the Grade 8 hardware, and there's certainly nothing wrong with that. If you have ever built a hot-rod engine, or read any articles about engine buildups, it is COMMON to use "ARP" grade 8 studs, nuts and hardened washers where extreme strength and reliability are needed. Even though this simple low-compression engine doesn't require the Grade 8 studs and nuts (or washers), I'll bet Dan NEVER has a head gasket failure once he's done with this engine. I think what he is doing is FAR more sensible than folks who toss the old studs, and replace them with bolts. What he is doing is an UPGRADE, not some "off-the-wall" goofy idea. An, it is a PROVEN, sound idea, based upon high-performance gas engines and diesel engines commonly being set up this way. The way he is using studs, installed into the clean holes makes it FAR less likely the threads will ever tear out of the block than if bolts were used. The sealant will keep the studs in place, and also prevent coolant leaks. For the folks who advocate BOLTS, they should have been around last week, when I had to remove 17 broken headbolts from a flathead V-8 block! However, I should have added, in my original post, to get slightly longer studs, along WITH the hardened washers.
