Another wheel wt question
Ross Provine
12-10-2006 19:57:03
I have a full set of pie weights with the mounting brackets and correct adapter bolts. A co-worker has a full set of sectional weights that bolt to the rim of a Ford tractor they weigh about 100 lbs a piece and there's four of them per wheel. My weights are about 45 lbs a piece and there's 12. Is this a fair trade? If not what would be the difference? Finally can somebody give me a value on either set up?
Thanks Ross
Ross
12-10-2006 20:25:59
 Re: Another wheel wt question in reply to Ross Provine, 12-10-2006 19:57:03
I'm afraid the pie weights won't fit the tractor I have. I bought them for a 55 Oliver. I thought about making a new adapter plate to make them work but they won't fit.
Thanks for the reply
Ross
old 9
12-10-2006 20:11:21
My advice stay with the pie weights. They are much easier to work with. I bought an NAA with the inside weights. They were NOT installed corectly and egg-shaped the holes in both centers. New centers not cheap! The draw-back on pie weights is they stick out farther than the wheels. my 2 cents worth, joe
