Order Ford 9N Parts Online
9n steering rebuild
RP-40-9n
12-12-2006 21:23:40
hey guys, getting ready to open up my 9n steering box. my right sector gear and possibly shaft and bushing are bad causeing my right wheel to jump out of control. left side is still good and tight. question- is there any rebuild info posted that might help me out? also if anyone has opened one of these up, i sure have a few questions if you wouldn't mind. thanks RP
RP-40-9n
12-13-2006 16:42:19
 thanks all in reply to RP-40-9n, 12-12-2006 21:23:40
with the good advice ,now i am confident i can get er done. thanks all RP
RP-40-9n
12-13-2006 09:14:50
 Re: 9n steering rebuild in reply to RP-40-9n, 12-12-2006 21:23:40
3 questions for now, and thanks
1, is there a gasket between upper and lower houseing,as my parts manual dont show one?
2,manual shows 3 inner&outer washers, is this for shimming?
3,any way to add a lube access? thanks again RP
Gasket....John,PA
12-13-2006 14:37:35
 Re: 9n steering rebuild in reply to RP-40-9n, 12-13-2006 09:14:50
Gettcha some gasket paper the same thickness and make your own. Do you know how to do that?
You notice that hole in the bottom of the steering casting. That is to allow oil to "spash" into the chamber.
John,PA
TheOldHokie
12-13-2006 10:50:04
The washers are really shims on steroids. Originally came in a variety of thicknesses to adjust gear lash but last I looked were no longer available. I turned some custom ones up to the specific size I needed. Give me a yell if you get stuck.
TOH
D Masury
12-13-2006 04:48:39
If you need sectors I have a whole steering box assembly with good sectors etc.... e-mail me if you want to discuss it.
David
nitebass9n
12-13-2006 04:39:52
I rebuilt mine too. It looked like I might need a sector gear, but once i got inside, It was the shaft and bushings. The shaft can get worn and seem to lean to one side slipping out more than the other. I used a large slim washer between the left sector gear and housing to shim the slop out of it. That saved a lot of $$. No new gear needed. Don't worry. Once you open it up you'll see how simple it is, and just what is and is not worn out. You might want to look inside before you buy stuff. you'll need new rope seals. order the IT manual. Your gonna need it for other things too.
OPEN..John,PA
12-13-2006 03:40:50
Howdy....I am OPEN to try to help ya...
I rebuilt my 9N steering a couple of years ago.
Fire away. John,PA
Recommendation..John,PA
12-13-2006 04:58:46
 Re: 9n steering rebuild in reply to OPEN..John,PA, 12-13-2006 03:40:50
Take your time and always WITNESS mark your sector gears. Infact , I always "witness mark" everything like starters, gennys, motors, gear teeth, etc. Actually speeds-up the job.
John,PA
