I was able to continue working on my non starting 53 Jubilee (12v conversion, diode method).Just to recap: Was running great. Then while idling it just stopped. Now, starter engages but tractor won't run. Here's what I had already done: Checked fuel flow at port on base of carb....good flow. Pull and clean carb with carb cleaner...no obvious fuel varnish found. Cleaned sediment bowl and screen. Changed spark plugs (Autolite 216, gapped 0.025) Had battery checked and charged at auto store. It still would not start. So, here is what I just did: Checked low voltage to 12v coil. It is 11.85v. Pulled #4 spark plug. Faint smell of gas in chamber and on spark plug from attempted starts. This makes me feel I don't have a fuel delivery problem. Held spark plug against bare engine. Hit starter button with ignition key on. No spark. Used a cheap Harbor Freight 12v 'spark plug tester'....no light from tester bulb when cranking engine. Pulled main coil wire and held about 1/16" from bare metal portion of engine. No "jumping spark" when engine cranked. I then ran out and bought another 12v coil! Ran back to the tractor and in the dusk tried the new coil....no start :-( I tested the resistance on the spark plug wires and coil wire with my Ohmmeter. Virtually no resistance recorded for any of the wires. I examined my distributor cap and rotor. They look virtually brand new with no wear on electrical contacts. And, for those who don't like the idea of a Pertronix electronic ignition....I removed the Pertronix and put my point/condenser back in. Gapped to 0.025....no start. What else can I do???? I need this tractor running but am at a loss. It has run great with good oil pressure (40psi while running).
