Ford Model 860 Air Filter
robshicla
12-19-2006 04:00:04
Where can I get an air filter for this tractor? I took the cap off and the filter rusted and falling apart. Also is this type still being used by placing oil to the fill line of the cap?
Dean
12-19-2006 04:59:37
 Re: Ford Model 860 Air Filter in reply to robshicla, 12-19-2006 04:00:04
Rob:
Both parts and complete air cleaner assemblies for your tractor are readily available from multiple sources. You can simply clean yours and replace the mesh.
These parts are probably available on this site. If not they are easily found elsewhere on the web.
Yes, you fill the oil cup to the "Oil Level" line with the same oil as used in your engine.
Dean
