Gas Leaking From Sparl Plug Hole
OldeSarge
12-24-2006 08:24:01
Last week I finially got the old ('40) 9n started and unbeknown to me, a sparkie was loose. I noticed after a few unseccessful attempts to start it that one of the plugs was not tight. Also, there was gas escaping from the plug hole. I wiped the gas away and tightened up the plug, did a few othere things and I got it to start, but it does run a little ruff. Is the leakage from the plug hole a Bad sign of something wrong inside or is this ok? Merry Christmas to All from and old lurker.
Ross Pugh(NC)
12-24-2006 09:14:18
 Re: Gas Leaking From Sparl Plug Hole in reply to OldeSarge, 12-24-2006 08:24:01
Ye said it runs ruff. Ye may need to check that plug and be sure it has a washer on it or it may be misfiring.
Ross Pugh(NC)
12-24-2006 09:10:38
Tightening the plug should have stopped the fuel from blowing out of the cylinder. Plug should be fine.
souNdguy
12-24-2006 08:52:28
I'd replace that plug.. it may have a bad gasket.. or at least be way fouled from not hitting good on that cyl..
Soundguy
ericlb
12-24-2006 08:38:19
if the plug was loose, the gas/air mixture will be forced past it when the piston comes up on the compression stroke, its not nessassarily a sign of something wrong , glad you found that befor it blew the plug out of the head and buggered up the threads in the head,
